Home > Technical (L322) > IID Tool - Amplifiler ECU errors
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Hi all,
Having purged my vehicle of faults (all caused by a low battery at some stage by the looks of it), I still have two coming from my AMP ECU .... basically giving an error with Speaker 1 and Speaker 2.
Anyone else have this?
Also, lowered the suspension 15mm, handles much better now, almost as well as the SC! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #113018 14th Mar 2012 1:41pm
interested re the 15mm lowering, i gather thats in standard mode?
what happens when you go to access , does it go 15mm lower than normal.. ... - .- -.
Post #113022 14th Mar 2012 1:49pm
DMRR
Hi Stan,
I haven't checked, but it is my understanding that all modes are now 15mm lower. It's at access right now and looks fine Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #113027 14th Mar 2012 2:17pm
sounds good,
i've always thought that the range seemed to high in standard mode so your 15mm lowering is a compromise to having to lower to normal access when stopping.. ... - .- -.
Post #113028 14th Mar 2012 2:28pm
SteveMFr
Site Sponsor
I believe our chief engineer, Christian, had this on his 2007. If I remember correctly it was chafed speaker wires under the RH front seat (directly in front of the BCM). Someone else had this too - was it Geoff (supershuttle)?
I'll see if I can get Christian or Patrick to post or find out more.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #113080 14th Mar 2012 10:20pm
DMRR
Thanks Steve Smile
I'll check all the speakers over at the weekend, but I've not heard anything *not* working, or any scratchy sounds..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #113082 14th Mar 2012 10:25pm
supershuttle
I never got round to fixing anything but the two upper speakers in the rear doors are silent. I did take the passenger seat out but ran out of time and so had to put it all back without reaching a conclusion or fixing anything. Geoff
Post #113087 14th Mar 2012 10:53pm
DMRR
Ah,,,well those will be the ones I'll check first then - oddly, I don't recall them ever running in my old 2006......had issues with the lower ones, and had them replaced.
Intrigued.... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #113089 14th Mar 2012 11:04pm
DMRR
All the speakers I could find seem to be working ..... how baffling Rolling Eyes Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #113787 19th Mar 2012 11:34am
supershuttle
Must be one of the ones you can't find because they are not making any sound Whistle
Sorry, unhelpful, but couldn't resist Very Happy Geoff
Post #113795 19th Mar 2012 11:54am
DMRR
<chuckle>
Just to confirm :
2 in the very back, 2 per back door, 3 per front door, 1 in the dash ....
That makes 13 + the sub .... is that right? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #113796 19th Mar 2012 12:04pm
supershuttle
I think 13 is right.
If the sound quality is OK I guess you can just ignore it although there may be a problem in the amp? - I haven't fixed my back door speakers yet, I didn't even know they weren't working until I got the IIDTool, probably 'cos I sit in the front I guess.
Obviously it could be intermittent, especially if its frayed wiring which SteveFR thinks mine might be, so clear the code and see how quickly it comes back I guess.
I'm sure you've thought of all this anyway Very Happy Geoff
Post #113797 19th Mar 2012 12:18pm
DMRR
Yep - but will do it again and get SWMBO to drive while I check each speaker Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #113801 19th Mar 2012 12:26pm
