Home > In Car Electronics (L322) > SatNav Volume |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Press and hold the "musical note" button on the touch screen unit (under the on on/off). It will go to the AVC/Volume settings. Land Rover Addict
15th Mar 2012 2:18pm |
Mutley Member Since: 29 Jun 2011 Location: Reading, Berkshire Posts: 172 |
DMRR oh thank you so much I could not find it in the manual but I was probably nodding off as there is so much information.
15th Mar 2012 2:26pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34951 |
also in nav mode you can increase the radio volume using the dash dial and the global volume via the steering wheel button.. ... - .- -.
15th Mar 2012 3:32pm |
Hi guys I have tried what you said about the settings but it has made no difference, i turned the nav button down to 1 & then next turn comes up loud as the radio really starting to me off that I can't keep the Nav a bit quiter do I have a fault?
18th Mar 2012 8:03am |
sounds like there may be a fault if it doesnt adjust using my method... ... - .- -.
18th Mar 2012 8:23am |
