Home > Technical (L322) > Can i fully drop my glove box down to get to fuse box?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
As above, is it possible to fully 'drop' the glove box lid/cover beyond the fuse-box access height? looked to see if it can be unclipped but couldnt see how to do it?
Post #113529 17th Mar 2012 2:09pm
No i dont think you can... Remove the glovebox is the only option depending on what your trying to do?
Craig Thumbs Up
Post #113534 17th Mar 2012 2:20pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Mne just falls down when I open it..! Can get access to fuse board no problem. Maybe press it little harder see if it goes down further for u.
Post #113535 17th Mar 2012 2:21pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
+1 not too bad a job to drop it though can be fiddly to get back if you disturb all the wires make sure nothing gets trapped behind there.
Post #113537 17th Mar 2012 2:22pm
mrblonde
cheers guys
Craig I need ot drop it lower than it normally goes Ive bough one of those plug in fuse dran tester things a lot of you guys have used, but the shape of it, and size of the part that pugs in wont fit the lower row of fuses Sad
Post #113580 17th Mar 2012 6:13pm
I used a pair of pointed pliers to push the blade fitting into each fuseway.
Don't remember a problem with the glove box.
Post #113597 17th Mar 2012 7:03pm
