Need mechanic advice re suspension bush fitting | |
Guys, been working on the Defender to swap out the crazy height suspension on the TD5 today, read an LRO article where they did it and the mechanic said 25 mins tops on each corner to remove and replace the spring and shocks. Seemed reasonable, its just bolts.
First one took just over an hour, and so I was happy with that.
Second rear corner I've so far spent 4 hrs on it. For some reason the top shock mount is too big for all the bushes, any bushes, even the old bushes wont go back on. I managed to get the first bush on (poly), then mount the shock but the 2nd bush just will not fit, there's something odd about the shock mount.
I've tried heating the bush in boiling water, using WD40, grease, nothing has worked and I'm not at the end of my patience
The only thing I can think of to try is to go at the mount with an angle grinder and sanding disc and trying to take it down slightly.
Would it be stupid to cut a slit in the bush in order to make the internal diameter larger? Would it matter really if there was a slice in it? I can't see how it would perform any less?
Anyone got any advice before I get REALLY angry? Discovery 4 HSE
1993 90 Tdi
