![]() | Home > Off Topic > Which Tape would you use |
Either …
What is it you want to mask off Mick? |
Blue 3M stuff Mick. As used by a lot of detailers. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
+1blue tape; Although never tried frog tape. |
Then Frog Tape for that then |
Either that or use black marker! |
What bits of the grills do you want to paint?
The outside frame and the thin bars that run across the grille from left to right |
should look tastey Mick |
Is the centre part of your front grill painted originally or (take a close look) is it metal covered? Hi end ones are metal covered with a matt chrome finish, therefore a different kettle of fish to paint...
Ah well can scratch that idea when trying to mask off the bars that i am wanting to paint it just won't happen and will cause the paint to run in to the cheesecutter part of the grille |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
Time for one of these then Mick!!! |
