![]() | Home > Maintenance & Mods (L322) > Front Door Exterior Window Surround |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7986 ![]() ![]() ![]() |
Hi all,
Many thanks Robert.
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
once you order the new trim is becomes obvious how its held on, i changed mine a few months ago and recall it was quite simple. the door mirror needs to come off for a start then undo the window, the rubber that runs around the outside of the door is held into the trim your going to replace so need to come off aswel to reveal some screws, cant remember the exact way i did it but there no need to worry about it, i used wax oil under the new trim and under the rubber to protect it in future. its worth ordering the trim that goes up the back edge of the door on the outside aswell, mine was slightly corroded like the front section. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16397 ![]() ![]() ![]() |
+1, not a hard job, quite satisfying though i recall... A series of small screws and rubber covers, but quite easy to do if your not too ham fisted with it...
Many thanks.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
mark, theres a video on the powerfuluk site re removing door cards, link in the wiki... .. ... - .- -.
