Home > Technical (L322) > No power when reversing on full lock
Olders
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Hi folks,
Bit of an issue looming I think - was hoping you may be able to help me diagnose....
Was reversing on full lock today and there was no drive. It felt a bit like when pulling away in deep snow with the snow program selected, i.e. you press the throttle a long way down but you get no revs. Fine in forwards and when reversing on a lesser steering angle.
I was in access height mode - don't know if that would make a difference?
Any ideas?
Thanks in advance! -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #113672 18th Mar 2012 10:17am
Do it again and see if it does the same thing... If so, get out and check the obvious... Stone under wheel, Mud flap touching tyre etc etc, if not put it up to next height and try again... We need alittle more info to try and help...
Craig Thumbs Up
Post #113677 18th Mar 2012 11:40am
daveo
its it ok with the wheels straight normal surface also try reversing up an incline to see if fails under load.. V8 facelift Range Rover Autobiography 22" wheels.
Post #113680 18th Mar 2012 12:59pm
Olders
Thanks chaps. Will do.
Will come back to you when I have tried your suggestions..... -----------------------------------------------
Post #113708 18th Mar 2012 6:44pm
ahebron
New Zealand
Stupid question but you didn't have your foot on the brake at the same time as the accelerator did you?
Occasionally when in my work boots I hit both pedals at once.
Adrian
Post #113715 18th Mar 2012 8:12pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
The older Freeloaders used to have this problem.
It was due to a viscous coupling failure. No idea if the same thing can happen in the fullfat or related to a central diff problem....I am sure someone else will fill us in with more info. Embarassed
G
Post #113716 18th Mar 2012 8:17pm
fisha
The rr has a torque biasing centre diff, which when it senses less or more grip front to rear will automatically try to adjust where the power goes.
On flat though it should really make much difference since all wheels have good grip.
I'd go with the other ideas first to see if it can be repeated ( does it do it on both sides of th lock ) and see if it's sticking on something .... I'd wager that's more likely especially if in access mode. V8 or else ...
Post #113737 18th Mar 2012 10:30pm
