Home > Off Topic > Glossary of mechanic terms
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
I thought it may be useful for us to prepare a glossary of commonly used technical terms by mechanics, along with translations! I'll start the ball rolling:
I'll call you when it's done = Stop hassling me I'll get round to it eventually. Maybe
We're just road testing it now = We hope to get it on the ramp today (or this week)
Bad news I'm afraid = Go get a remortgage on your house, and a quote for your kidneys
Haven't managed to locate the problem = We're going to charge you lots of money for not fixing your car
Can't duplicate the problem = See above
Found a broken (insert here), but can't be sure it will entirely fix the issue = See above
Good afternoon (insert name) Land Rover, service department = See above x 10
Anybody else have any? 2012 SDV8 Vogue SE
Post #113843 19th Mar 2012 6:00pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
The sharp intake of breath through teeth is usually is a bad sign! Crying or Very sad
Post #113846 19th Mar 2012 6:20pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
"I'm a technician"=I'm a retard with no mechanical ability.
Post #113855 19th Mar 2012 7:31pm
That parts on Back Order , Anyone's guess when you'll get your car back Sir …..
Post #113858 19th Mar 2012 7:38pm
ebajema
We're detailing it right now = we trashed the hell out of it all week using it as service car and got our greasy hands, soft drinks, donuts, meat pies and other crap all over your car, dimwit. MY 2010 5.0 SC Galway green and sand interior!!
Post #113884 19th Mar 2012 8:34pm
We'll call you when it's ready = when it's ready, we'll leave it sitting there and have no intention of calling you at any point until we're about 5 minutes from closing for the day.
Or, 'why don't you f**king call us as we really don't give a tin sh*t and we assume you do!' Si. <This is my name.
Post #113890 19th Mar 2012 9:04pm
Turbo Tony
"We were just about to call you to tell you your car's ready for collection" - We've only just reloaded the invoice printer with enough paper to print your bill.
"We'll offer it up and see" - I've never seen your model of car in my life, so I'm going to try my luck with a hammer and some WD40. Researching my first Range Rover purchase
Post #113902 19th Mar 2012 9:47pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
TOOL GUIDE:-
AIR COMPRESSOR: A machine that takes energy produced in a power station 200
miles away and transforms it into compressed air that travels by hose to a
pneumatic impact wrench that grips rusty bolts last tightened 60 years ago
by someone in Birmingham, and either breaks or rounds them off.
ANGLE GRINDER: When used to just take off that tiny burr – effectively turns a perfectly painted panel into a surface resembling that of 30 grade sandpaper. If a wire wheel is attached, can also be used by the more extreme body mutilation aficionados and, for riot control; those sharp little wires shoot off in every direction and, at amazing speed.
BACKSAW: Invented by William Back, the sawdust magnate. Used for recycling excess floorboards.
BALL-PEEN HAMMER: Interestingly, when first discovered in a cave by Fransco de Gama in 1602, the ball-peen hammer was useless, as the peen had not yet been invented, and the practice of hitting yourself in the balls had already been perfected by the Druids, using a variety of devices. Ball-peen hammers are now used by those with steady hands to swat flies. Also used as a universal centre-punch.
BATTERY HYDROMETER: A handy tool for transferring sulphuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
BRAKE PIPE FLARING TOOL: A device for increasing the diameter of the ends of brake pipes, which is so stupid, that it doesn't know that when the pipe fits perfectly, one of the unions has either been left off or put on backwards.
CIRCLIP PLIERS: Used to prise the lids off paint tins. Work better, if you snap off those silly little nibs that fit circlips.
CROWBAR: A tool used to crumple the metal surrounding that tiny clip or bracket you needed to remove in order to replace a 50p part.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
ELECTRIC DRILL: Normally used for spinning Pop rivets in their holes until you die of old age.
GASKET SCRAPER: Theoretically useful as a tool for stirring tea or spreading mayonnaise, however, used mainly for getting dog-crap off your boot.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit. Also used for bending nails. If used properly, nail will bend, then fire itself across the room, as it is now useless anyway.
HOSE CUTTER: A tool used to cut hoses 1 inch too short.
HYDRAULIC JACK: Used for lowering a car to the ground after you have restored your brakes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG 4x2: Used for levering a car upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbour to see if he has another hydraulic jack.
LEAD LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 60-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle
of the Bulge. More often dark than light, its name is somewhat misleading.
MOLE WRENCH: Used to round off bolt heads and to transfer intense welding heat to the palm of your hand.
OXY-ACETYLENE TORCH: Used almost entirely for igniting various flammable objects in your garage. However, is also capable of causing the prone user to get out from underneath a car at the speed of light, when the white hot blob of braze won't take on the exhaust silencer, you were hoping might last another week or two, and eventually falls on your chest.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round out Phillips screw heads.
PLIERS: Used to round off bolt heads.
SCREWDRIVER: Device used for opening beer cans. Also serves as a chisel. Primarily used for removing excess skin from palm and making random gouges in things.
SILVER SOLDER: Although this item was designed before the invention of plastic, its main intention is as a replacement for twist-ties. Also used to prove the "no two snowflakes" theory when melted above finished floors. It has been said that Pershing used solder to practice bombing raids on cockroaches.
STANLEY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing custom made leather goods.
STAPLING GUN: Invented by Charles Atlas for developing the forearm. This tool should never be used for trying to attach one item to another, as staples are not made in that size.
SU ADJUSTING SPANNER: Teeny 1 1/2" long mini-spanner; drop into the inaccessible recesses of your engine-bay, to simulate that vintage intermittent rattling noise. If you don't want that vintage sound, it can easily be retrieved, see under two-ton hydraulic engine hoist.
TIMING LIGHT: A stroboscopic instrument for illuminating grease build-up.
TIN SNIPS: See hacksaw.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of earth-straps and other lines you may have forgotten to disconnect.
16-INCH SCREWDRIVER: A large engine-mount prying tool that inexplicably has an accurately machined screwdriver tip on one end and no handle on the other.
WHITWORTH SPANNERS: Once used for working on older cars and motorcycles, they are now used mainly for impersonating that 9/16 or any other you've been searching for the last 15 minutes.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under
the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Ouc...." See also angle grinder.
CHEMICAL SECTION
CAUSTIC SODA, FOLLOWED BY NITRIC ACID: Used for dissolving gummy deposits on
SU fuel pump filters, then dissolving the filter.
GUNK: Invented by Forrest Gunk. Gunks' primary component is mayonnaise, but perfume and lanolin are added to make mechanics hands soft and lovely. Also used for lubricating fipe fittings, and for getting rags dirty. Do not eat. Once applied to skin, Gunk never comes off.
IMPACT ADHESIVE: Used for removing the slots between your fingers.
LACQUER THINNER: Used to cool skin. Also used to make lacquer useless. This chemical was invented by E.I. DuPont de NeMours for the purpose of making money. Creative mechanics often use lacquer thinner to tie-die trousers while wearing them.
MINERAL SPIRITS: Aka paint thinner, enamel thinner, stuff. Used for wetting metal parts. Also used for adhering paint brushes to containers. (Note: process takes approx. one month) This chemical can be used in place of any other chemical with reduced efficiency.
SILICON WAX: Used to ensure that paint will never, ever adhere, ever again.
PRE-PAINT CELLULOSE THINNERS: Used to ensure that any silicon wax present, is distributed more evenly over the surface to be painted.
WD40: Deceptive oil-like substance, for making rusting parts rust faster, but smell nice.
Post #113975 20th Mar 2012 10:26am
Stephen.125
Rolling with laughter Rolling with laughter Bow down
Post #113992 20th Mar 2012 11:03am
