Home > Technical (L322) > Side Repeater Indicator Fitment
mjdronfield
Does anyone know what is supposed to actually hold the little round indicator in the front wing ?
Since I've had the car, the passenger side one moved about in the wing, up down / left right, but now its at the point where you can just take the unit out with the end of your finger.
I'm sure it's going to drop out as I'm going up the road.
The handbook says that you put it in and slide towards the right........but there is nothing for it to lock into.
I've a feeling I'm a rubber seal, or some little clip missing.
Any help gratefully received !!
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #113671 18th Mar 2012 9:55am
supershuttle
Mark,
They are loose, I swapped mine for some Powerful ones and they were also loose and I have since swapped back on instructions from SWMBO as she liked the white ones better.
They shouldn't however move around too much, try a bit of foam tape (double sided with one side still covered should do it) on the back of the lamp. I don't think they will actually fall off though because the bayonet fitting for the bulb, on mine anyway, is pretty tight but you would still look a bit of an Censored if it was hanging out by the wire. Rolling with laughter Geoff
Post #113675 18th Mar 2012 11:12am
There should be a plastic spring clip on yours, they brake off often so dont hold it in place... Renewal or double sided tape repair is really the only way unfortunately... I would either replace it or stick it in with some double sided tape before it falls out on the motorway and wrecks your paintwork flailing around!
Craig Thumbs Up
Post #113676 18th Mar 2012 11:35am
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
I've just replaced mine with genuine Land Rover parts bought on fleabay, they were around £12 for the pair & fit perfectly.
Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #113698 18th Mar 2012 5:35pm
mjdronfield
Thanks all.
So am I right in thinking that the actual front wing has nothing around the hole, and that all the necessary fastening clips and stuff are on the indicator unit........
In which case, it may be easier to just get a new one, from somewhere.
All the best
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #113775 19th Mar 2012 10:22am
ebajema
I fitted the clear ones on mine and as long as the plastic clip is "working properly" things are fine. I agree to not let them flail around at all. MY 2010 5.0 SC Galway green and sand interior!!
Post #113779 19th Mar 2012 10:48am
supershuttle
Nothing around the hole, but it has two cutouts either side to accomodate what should be a locating lug on one side of the light holder and a spring clip in the other - both part of the moulding.
Like Craig says the clip could break off, in which case double sided tape or a new repeater. Geoff
Post #113783 19th Mar 2012 11:15am
mjdronfield
Excellent. Many thanks.
I have no spring clip.
The one on the other side is pretty solid, as I initially tried to remove that one to see, and then thought it was best left alone !
I shall source a replacement unit.
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #113784 19th Mar 2012 11:19am
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #113785 19th Mar 2012 11:20am
mjdronfield
Thanks Stan.
I definately have no spring clip.
Makes sense now.......
I have watched most of those videos, but obviously not that one.
All the best
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #113786 19th Mar 2012 11:25am
mjdronfield
Well, the Land Rover dealer in Chesterfield have a single indicator unit available for £34.83.
"We can discount some of that, so it'll be £29.61".
So I have just bought 2 used ones off the bay of e for £5.50 delivered.
Sorted........
Thanks again.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #113792 19th Mar 2012 11:42am
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
i have two orange ones if you want them.
Post #113881 19th Mar 2012 8:30pm
andyboy
sorry i didnt see your last post Whistle
Post #113882 19th Mar 2012 8:31pm
mjdronfield
Thanks for the offer mate.
If the ones from ebay arrive with broken spring clips, I'll take you up on it !!
All the best
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #113949 20th Mar 2012 9:23am
Sorted........
Thanks again.
Mark
Well, i must be sat on a gold mine here with all the old orange ones we remove and bin... Anyone need them second hand? Say at a 5% discount!!! Whistle
Twisted Evil Would make a fortune!!! Rolling with laughter
Craig Whistle
Post #113952 20th Mar 2012 9:36am
