Home > Maintenance & Mods (L322) > Front wheel bearings
Has anyone done one at home yet at all as mine seem a bit noisy?
I've got to jack her up and have a good feel but price seems to be about £30 each side.
I've done some on other cars before where it's a hub off and press out job but being a much bigger vehicle bet they weigh a tonne!
Any advice greatly welcomed Smile
Post #85345 4th Oct 2011 10:15pm
It's straight forward enough if you can use spanners and have access to a hydraulic press. I removed the complete assembly from the vehicle. You need to remove transverse and compression links, track rod end, bottom strut bolts brake caliper and slider, disc, and anything I have forgotten....Remove driveshaft hub nut and press driveshaft out of hub leaving it attached to the vehicle (this is a very tight fit and you will need something like an air hammer to push it through. Next from the rear of the assembly press out the hub and the wheel bearing will be seen. I cut part through the seats with a cut off tool and chisel them off. You need a proper press to refit them and ensure they are in properly.
The hub nut is a 36mm 12 point socket.
Post #85351 4th Oct 2011 10:28pm
Cheers fella Smile
I think i'm going to have to get somewhere to do it as i don't have an air hammer and while i could do the majority of it i'd still need to get it to a local place with a press to get the old out and new in Sad
Maybe i'll see if i can find one of those garages that rent out lifts and tools and do it there. They were featured on 5th gear a few years back but haven't seen any pop up at all Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #114149 21st Mar 2012 1:56am
actually a quick 5 minute google shows there is a rent a ramp type place about 40mins from me so even with fuel factored in i reckon about 3 hours to do the job and if they have a press and tools onsite that may save me about £100 including the bearing Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #114152 21st Mar 2012 3:16am
Please be warned! They can be a real s Censored t... You get one that wants to fight you and its a pig all the way through!
Check your driveshaft nut has not corroded to nothing before you attempt, the lower shockmount bolts will move and you will definately need a large press for the driveshaft, they never tap out!
Craig Thumbs Up
Post #114185 21st Mar 2012 10:36am
OH Sad may just book her in next week.
This place in holmewood i think it just off the M1 has an onsite mechanic on hand apparently so i'll sound them out just to see as if its cheap hourly rental i could probably book it for a fair while and still come in quids cheaper as its only £15 to get there and back in fuel... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #114245 21st Mar 2012 5:19pm
mjdronfield
If you rent a ramp in Holmewood, I'd be interested to know how you get on, as its only 10 or 15 mins from me.....
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #114278 21st Mar 2012 8:32pm
