![]() | Home > Maintenance & Mods (L322) > Venturecam mount |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Good work
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746 ![]() ![]() |
Hi chaps not sure how to post e bay links but if you search Camera suction mount that seems to bring up the mount then digital action mount or sports camera mount brings up the camera holder. I just use the two back to back using the velcro straps that should hold the mount to a bike etc to hold the venture cam then just screw the two mounts together both going half way into the lock nut if that makes sence. I have since made up a little 1/4 whitworth adaptor to hold them together but the half and half way works fine. |
'sense' sorry tipo Mine was a blue one! |
Do you mean, something like This bolted back to back with Something like this. |
Thats the babys |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Already got (a), how do I fix (b) to (a) as they both have male fittings?? |
Hi both mounts come with a locknut to adjust how far you screw the camera on, you just (being rough) screw the male fittings into one of the locknuts from both sides until they lock together. As you dont need to undo it again you could use a bit of studlock or superglue to make sure it wount come undone but if you gentle grip the male thread on the suction mount with pliers while screwing the other one in it locks together quite well. You could reduce the length of one or both of the male threads but it can limit the amount of articulation available. Or make up a little 1/4 whitworth adaptor |
Cool, sounds good, thanks! |
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
Is it possible to record from a Venturecam, either onto a laptop or on the FFRR? I ordered one for my Westminster and wondered how it could be done. |
Hi Oldcro
Somebody suggested this link:
I thought the OEM to landrover was G-Force mounts they even say so on their web site but as you corectly say you can buy the mount but not the pocket/holder for the Venturecam
