Home > Maintenance & Mods (L322) > Handbrake sleeve- glue or not?
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
I recently put a new gloss black sleeve on, it doesn't have a clip like the original sleeve and slides off easily. I have tried whacking it on but still comes off.. Any ideas how to keep it on? Is glue a bad idea? Would I ever need to take the sleeve off down the line?
Thanks
Post #114382 22nd Mar 2012 1:02pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
If it's a reasonably tight sliding fit already, then it's worth trying the ploy used to stick handlebar grips on motorbikes.
Liberally coat the inside of the sleeve with hairspray - then, while it's still wet, slide on the sleeve and leave it alone for a while. The solvents in the hairspray will evaporate and the remaining "gunge" will stick the sleeve on. Can be removed if ever you need to with a hairdryer...
Post #114387 22nd Mar 2012 1:24pm
Lolo
Does it matter which brand of hairspray, loreal or tresemme extra strong hold might be better option...
Only jokin, sounds like a v good idea I'll try it later, thanks Thumbs Up
Post #114396 22nd Mar 2012 3:16pm
Simes
Is she... Or isn't she....
Post #114397 22nd Mar 2012 3:29pm
