Home > Maintenance & Mods (L322) > Rear driveshaft hub nut
fisha
Been looking at some of the jobs I need to do come the summer, one of being to redo the rear bushes.
I had wheel off this afternoon and looking at the hub nut, it looks like a pile of rust. Scraped at it with a screwdriver to see if I can see the nut teeth and I can't, I'm thinking this might be a bit of an issue !
Anyone one the job recently with a well rusty setup and got any tips.
I'm quite used to these sorts of jobs, so the concept of dong the bushes etc doesn't daunt me, just looking for any tips. V8 or else ...
Post #114585 23rd Mar 2012 7:12pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I'm looking to do the same, my hub nut is a nugget of rust too.
Apart from attacking it with air ratchet and socket, no idea.
It looks like it may crumble the first time any torque is applied to it, hopefully it'll just fall apart... (wishful thinking)
Post #114588 23rd Mar 2012 7:20pm
fisha
Rust nugget .... That's sums it up for me too.
I have a smaller set of the sockets that have teeth on them that bite into the nut when you undo it, I'm wondering if I can get larger ones and hammer it on and basically rip into it to get it undone.
I'm dreading it a bit the more I think about it.
The brake lines look gubbed as well ... Thinking about making Goodrich hoses to run from the caliper to the point the pipes meet the main body ... Would be better than the multiple joins there is at the moment running over the arms. V8 or else ...
Post #114589 23rd Mar 2012 7:27pm
Richcl
I know the sockets you're on about, "Urwin" I think they're called, 21mm seems to ring a bell on maximum size.
If all else fails you may have to trash the driveshaft and grind/hack/butcher the nut off.
I think I'll have to sort rear bushes out soon, as I'm getting a knock from the left rear, when ever I turn left. I noticed that poly bushes are available for the rear, maybe a viable option.
Post #114597 23rd Mar 2012 8:14pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Who does the polybushes. ? onto no6 Range Rover
Everyone needs a hobby
Post #114600 23rd Mar 2012 8:42pm
Richcl
http://www.polybush.co.uk/shop/view/713_Ra...(Series_3)
Post #114604 23rd Mar 2012 8:53pm
fisha
The polybushes look like inners only. it's the outers I'm needing to do.
Any one know the size of the nut ? V8 or else ...
Post #114663 24th Mar 2012 4:41pm
Yep, mine looked like a rust nugget too, but I reckon with a clean up a good dosing of WD40/easing oil, the right socket and a nice long breaker bar, it should move.
Reckon I need to replace all my rear bushes, significant outer tyre wear starting to show after just a year from new Grabbers, so will welcome a nice picture howto of all the dismantling and refitting Wink .
Post #114667 24th Mar 2012 5:22pm
Richcl
Noticed my tyres are wearing on the inside, so looks like it wont be long before I'm changing bushes on the rear.
Post #114669 24th Mar 2012 5:31pm
fisha
I'll take pics when I do mine, but it may be a wee bit away yet... Not sure if I want to take the rr off the road 7 wks before the wife is due .... Either way, it'll need done before nov and the next mot. V8 or else ...
Post #114675 24th Mar 2012 6:59pm
I'd give it a wallop with a hammer as well to unlock the rust lock that will have been created and also try a little jet on it then an ice cube on the threaded driveshaft part to keep the nut a bit warmer and thus a little oversized and easier to get off if your quick Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #114677 24th Mar 2012 7:15pm
fisha
Actually, I think I'll video it .... Hearing me swearing will give you a bit of a laugh, and all you US chaps can see what real rust is like. V8 or else ...
Post #114682 24th Mar 2012 8:05pm
You don't need to touch the hub nut when changing the rear bushes
Post #114690 24th Mar 2012 9:15pm
