Home > Technical (L322) > Clonking / noisy wipers - SOLUTION!
itguy
2006 Range Rover Vogue Td6 Cairns Blue
Hi everyone
Had very noisy wipers on my FFRR ever since I've had it and got really fed up with it tonight so have totally sorted them.
Solution as follows;
Driver side wiper was hitting the A pillar so adjusted in line with RAVE, now silent on that side. It just needed moving down slightly on the spindle.
Passenger side - this was again too high and got moved down to sit correctly when parked, however the most difference to the noise was changing the angle of the wiper against the windscreen. I adjusted the angle to be 90 degrees to the windscreen as that was all the wiper adjustment would allow - and found that the blade was wiping against the flow of the wiper - hence the noise.
So - I took the blade off and filed out the adjustment hole some more so I could get the angle that RAVE says (86 degrees against the window when parked) and now it's perfect - no noise what so ever at any point of the wiper sweep.
Well chuffed!
One other thing people might not realise is - the black strip at the bottom of the windscreen that your wipers should park on has separate heating elements that automatically come on with the washer jet heaters - specifically to keep your wipers from freezing when driving in freezing conditions where wipers might not get used often.
Good stuff eh!? FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9566 16th Dec 2009 8:47pm
Will, you're rapidly becoming more obsessed by the day!
Go out and drive and enjoy it!
I've got to travel to slough tomorrow which normally I would be unhappy about, but the prospect of 260 miles in th TDV8 VSE brings a smile to my face! Very Happy Discovery 4 HSE
1993 90 Tdi
Post #9570 16th Dec 2009 10:28pm
itguy
I know what you mean - with the snow forcast too - should be a right laugh!
I too look forward to my trip to work much more than I used to - knowing the car will be warm on the drive waiting for me and I will be wafted along Smile FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #9572 16th Dec 2009 10:33pm
Will,
Did you adjust your wipers so that they parked on the lower black strip properly?
Mine don't park there but I have put it on the list for the Dealer next week Thumbs Up Discovery 4 HSE
1993 90 Tdi
Post #11423 22nd Jan 2010 6:47pm
The doc
2008 Range Rover Vogue TDV8 Java Black
It's very easy to do - I'd DIY as you KNOW they'll feck it up '09 Freelander 2 TD4 HSE Auto for the Mrs
Using the works Fiesta 1.6 TDCI Sport Van - CHROME FREE THOUGH
Searching for a nice E63 AMG or S8 V10 to replace my "wonky" TDV8
Post #11424 22nd Jan 2010 6:54pm
itguy
Yep - they now park in the black strip along the bottom.
Very pleased with the front wipers now. Silent operation and always kept unfrozen during the snow / below freezing conditions FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps
Post #11471 23rd Jan 2010 9:01am
Might do mine tomorrow then and scrub it off their list, they have enough to do! Laughing Discovery 4 HSE
1993 90 Tdi
Post #11516 23rd Jan 2010 8:26pm
The doc
Its easy and self gratifying Thumbs Up '09 Freelander 2 TD4 HSE Auto for the Mrs
Post #11519 23rd Jan 2010 9:50pm
My wipers now park correctly but I think they make more noise than they used to, only upon the switch from backwards to forwards at the end of the motion. It makes sense in a way because the wiper blade has to turn over.
Has anyone cured this noise easily? Can we fit flat blade wipers to our cars because Costco are selling Goodyear Assurance ones for about £6 each but I wasn't sure about the fitting compatability so bailed out. Discovery 4 HSE
1993 90 Tdi
Post #12655 7th Feb 2010 10:19pm
Shandonman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Couldn't find any more recent thread than this.
Was there ever a solution to the clonking on the change of direction ? 2002 Vogue 4.4 V8
1995 Disco 1 300tdi
Post #344696 27th Aug 2015 9:50am
http://www.fullfatrr.com/forum/topic10025....wiper+thud
or replace with bosch 808 or the 'aero' type.. ... - .- -.
Post #344698 27th Aug 2015 9:56am
Weegie
"or replace with bosch 808"
Fixes it.Thumbs Up John
GAP iiD BT-Sold
Post #344716 27th Aug 2015 11:06am
dazza1983
I know this is a old thread but how does one get the correct angle of the blade? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #533066 3rd Nov 2019 7:58pm
