Home > Technical (L322) > GM kickdown stutter
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
GM kickdown stutter
I recently did my annual transmission oil change with the correct Texaco fluid, checked the level at 43C and also followed the instructions to reset the gearbox controller (ignition off;pedal to the metal; ignition to position 2; continue holding pedal to metal for 60s; ignition off; pedal release). I then did a 5 mile drive to verify that the gearbox was happy - it was much quieter than before and kick down was happy.
However, this morning on kickdown (after about 3 miles from cold) I'm now getting "rev hunting" which sounds (before I rapidly back off) as though the gearbox is cycling between two gears - I'm thinking that maybe the fluid level is slightly low when cold (hoping the gearbox at 80k miles isn't starting to fail) ...
All suggestions welcome!
Post #115181 28th Mar 2012 9:48am
RRPhil
You have a TD6(?) - so it has the GM rather than the ZF transmission.
Did you have the engine running at tickover as you set the final fluid level?
Phil
Post #115204 28th Mar 2012 12:00pm
VaguelyVogue
Whoops - no the engine was off (and yes it's a GM - title edited now)!
I will test the fluid level with the engine running this evening - thanks for that Phil Thumbs Up.
Post #115215 28th Mar 2012 2:45pm
RRPhil
No problem Smile Both the ZF & GM transmission fluid levels are set with the engine (and therefore the transmission oil pump) running so that the torque converter, oil cooler and its pipes are all full of fluid and not draining back down into the sump. In addition you should also move the gear selector lever through each of its positions (holding for 3 seconds in each) and then back to Park just before the final level is set to ensure that the valve block galleries are also full. You already know about the importance of the fluid temperature.
Phil
Post #115229 28th Mar 2012 4:11pm
@ RRPhil
aside from the above, anything you would add/remove from the howto on the wiki:
(see the bit about letting oil out again when engine off ?)
and is resetting the gearbox controller of any help ?
I ask because I am about to do the oil change, now my new GM box has reached 25K miles
(and no, I still haven't got around to fixing my High/Low transfer problem Wink) .
Post #115241 28th Mar 2012 5:53pm
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
Thinking of getting my gearbox flushed,
57 4.2 s/c , any one in here know anyone decent in or near
Blackburn, North West
Sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #115294 28th Mar 2012 10:17pm
RRPhil
@ Joe90
Yes, having read it, the advice given in the Wiki is incorrect. The guy describes how the filler plug was removed with the engine off and, not surprisingly, fluid poured out as the torque converter and valve block started to drain down. This would have resulted in the transmission being significantly underfilled. If you remove the filler plug without the engine running, and the transmission began with the right amount of fluid in it, you should get over a litre of fluid down your arm.
Also, now I'm on a roll Smile, could I implore people only to use the genuine Filtran filters in their transmissions. In the long run it really isn't worth the few quid that you save in using a cheap pattern part imported by a reboxer from Taiwan/ROC or wherever.
Phil
Post #115298 28th Mar 2012 10:21pm
salb
Actually wonder if rrphil can do this, as I am in Blackburn
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #115299 28th Mar 2012 10:24pm
RRPhil
Sal,
Have you decided to get the fluid changed in your 6HP26 then? I wasn’t certain because of Cam-Tech-Craig’s post about the official notice that the dealers had received from Land Rover rescinding previous advice to replace the fluid for just about each & every problem identified with the transmission. I’m interested in the technical reasons Land Rover gave for this and wondered if Craig had sent you a copy of the notice?
Phil
Post #115304 28th Mar 2012 10:45pm
salb
Hi phil,
Yes I have as I'm not sure of the box for life issue,
The slight thud I get now and then is apparently normal,
But I did take the advice from Craig and sat on it, as I was fairly
New to the site I didn't actually send the pm to Craig that I thought I sent Rolling with laughter .
But what are your thoughts, I'm just thinking to prolong the life of the box I'm sure that if
You clean all the Censored out, that this would actually help the box.
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #115305 28th Mar 2012 10:53pm
Martin
Site Admin
Guys, you can edit the wiki yourself to correct or add information - that's the whole point Wink
Post #115323 29th Mar 2012 8:53am
VaguelyVogue
I tried Martin - but it says that the topic is locked. The text that I wanted to add (given Phil's advice) was:
- If possible, use a genuine Filtran replacement filter
- Replace fluid with fresh fluid until it starts dripping out of the fill hole
Both the ZF & GM transmission fluid levels need to be set with the engine (and therefore the transmission oil pump) running so that the torque converter, oil cooler and its pipes are all full of fluid and not draining back down into the sump.
- Start engine, hold foot brake down and cycle through each gear position holding for 5s (from park to drive & back) to ensure that the valve block galleries are full. Ensure that you finish in Park with the handbrake on.
- WITH THE ENGINE STILL RUNNING wait for the transmission fluid to reach 43C and top up as necessary
- Refit fill plug, tighten and turn ignition off
- Reset the transmission/ gearbox controller (with ignition off, push accelerator pedal to the floor; ignition to position 2; continue holding accelerator pedal to floor for 60s; ignition off; pedal release)
Post #115347 29th Mar 2012 10:30am
Martin
Site Admin
For wiki permissions see here: http://www.fullfatrr.com/wiki/Help:Contents
One quick button click Smile
Post #115351 29th Mar 2012 10:42am
VaguelyVogue
Joined the group, logged out & in (just in case) but "How to change Td6 automatic gearbox oil" still locked in the wiki Big Cry
Post #115374 29th Mar 2012 12:01pm
Martin
Site Admin
Right - that's because it's a link to a forum thread, not a wiki page.. Confused
Post #115375 29th Mar 2012 12:03pm
