![]() | Home > In Car Electronics (L322) > Removal of sub woofer.. |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
My woofer is vibrating v badly and buzzing since i bought the car so i just turned it off,I am hoping it's just the cone or whatever u call it that is damaged, has anyone tried the powerful uk replacement? http://bit.ly/GUTajo
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
I had "sub-woofer " buzzing until I looked closely and found an aerial connector/amplifier bolted right next to it on a single bolt bracket was resonating, with the loose end touching the steel body of the car creating the noise.
No rear parcel net, I'll do some investigation later to confirm.. |
My Sub kept undoing itself ... check the securing bolts and use a bit of locktite to avoid it reoccuring. Land Rover Addict
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
Lolo, the powerfuluk one is an OE part, i have fitted them to my customers cars to replace shot subwoofers and can confirm they are a 100% fit (as long as yours has one large sub not two small ones) I replaced mine too (was not even blown!) but at that price, i knew it was just a matter of time before mine went... Sold my old one for £55 on the bay... Result i say!!! Grab them before he runs out of stock if i were you... Craig ![]() |
Removing the sub is not too difficult. I had that panel off more than once - but it's been a while. The guy in this thread says you have to remove the c-pillar trim but I'm pretty sure I didn't. What I wrote up is in the thread.
can't believe this was an easy fix.. First time ever.. All I needed to do was tighten a few bolts.. |
I was right |
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 ![]() ![]() |
Lolo , How many vibrating , buzzing things you have in your trunk . Its looking like your are ......obsessed ???? ![]() ![]() ![]() ![]() ![]() ![]() 2002 V8 , premier edition , 19" alloys , |
