Home > Technical (L322) > ZF transmission problems |
I had a board member and IIDTool user PM me with a series of faults he had on his RR. His questions and my reply is below. Does anyone have any additional input?
27th Mar 2012 8:14am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 915 |
Hi Steve,
27th Mar 2012 10:39am |
To be honest Michael yours does sound like the ‘classic’ A-clutch leakage issue caused by a split O-ring due to failure of the axial needle bearing between the B-clutch hub and the C-clutch drum.
28th Mar 2012 11:39am |
Mandu Member Since: 03 Dec 2011 Location: Darwin, Northern Territory, Australia Posts: 9 |
Thanks for your assessment Phil. Having read many of your posts on transmissions with similar symptoms I thought as much. However with the high cost of getting a transmission reconditioned we always live in hope.
28th Mar 2012 1:14pm |
Phil
3rd Apr 2012 2:08am |
Hi Michael,
3rd Apr 2012 12:30pm |
grimlock27 Member Since: 12 Apr 2014 Location: Riverside Posts: 7 |
Hi, I just joined because I seem to be having the same problem. I haven't had any codes read yet but when the engine is cool all is well but once it warms up it has a problem shifting into first gear. It hits it with a thud. All other gears are good. I just had the transmission filter and fluid changed the day before it started happening though, I put in the Valvoline Max Life that says it works for LT1171 so I am wondering if this is a coincidence or if maybe that fluid is not any good in this transmission. After scouring I found some people who say the green label transmissions must have the yellow fluid which I have now ordered. I have a hard time believing its the transmission because ZF transmissions are incredible and I've never seen a bad one.
12th Apr 2014 9:52pm |
Seems a heck of a coincidence that the problem started immediately after the fluid & filter were changed. Did the shop doing the work definitely know that the engine had to be running when the fluid level is set, otherwise the transmission will be under-filled? You should only use Mobil ATF LT71141 / ZF Lifeguard Fluid 5 in your 5HP24 (and a genuine Filtran filter)
13th Apr 2014 11:41am |
Yeah, I know. Im definitely on board with this issue being a viscosity issue. Once the fluid gets hot it is causing a problem in the transmission. I'm hoping the valvoline max life is not staying at the same viscosity as the official stuff so thats where Im going to start. I'm not buying a fault in the transmission yet. I don't believe ZF transmissions fail unless there is a problem outside affecting them. I read about the overheating issue with the radiator and I read that enough times the sensor won't pick up the fault. If thats the case then the codes that do get thrown are probably irrelevant since the transmission will think the gears are failing, things are slipping, etc all due to extremely high viscosity. What I read is it takes 25 minutes for the transmission to begin to overheat from cold so I drove mine last night until the engine reached full running temperature and it was still shifting seamlessly. I decided a few minutes later to take it home and not deliberately overheat it. The crack in the valve body (or where ever it is exactly) also spells out a result of extreme heat to me. Whats the best way to measure the temperature of the tranny? A laser gun?
13th Apr 2014 3:52pm |
When you guys say your transmissions begin to slip when the car warms up how do you define warmed up? When the temperature needle hits 12 o'clock or 25 minutes into driving or what? Like I said, mine was warmed up. Needle was at 12 o'clock and it still shifted fine. Not sure how warm the tranny is at that point but its supposed to be overheating in 25 if theres a cooling issue |
13th Apr 2014 3:59pm |
This is the cheapest place I found for the "official" ZF fluid. Its a 6 pack for 88 bucks. Is there anyplace cheaper?
13th Apr 2014 4:08pm |
I read a lot of cofused messages about whether or not peoples transmissions are overheating. I don't know if its posted somewhere but it would be a good idea to establish what is normal operating temperature of a range rover. I read online a transmission shouldn't go above 220. I'm going to buy a laser gun from harbor freight and see how hot mine gets idling on the driveway first. I think a laser gun would be a reliable method of testing the temperature right? Maybe shoot it from different places and the cooler lines also... It would save time instead of speculating and pulling parts unnecessarily. |
13th Apr 2014 4:27pm |
As I suspected, I let my range rover idle in the driveway for half an hour and reved it for a couple of minutes at 2500 rpm (literally a couple of minutes) and while the engine surface temperature was around 180 the transmission was 220 and went as high as 240. The coolant lines feeding the transmission were 167 both. Apparently blocked to be reading the same temperature? This is merely idling in the driveway. No codes. No warning. Nothing. I didn't think the ZF fails since I used to redo discovery 2's and resell them. Never once did I ever come across a bad ZF transmssion. As for the failed parts inside these transmissions I would say they are due to the sensor not registering the overheating issue and people continuing to drive them. Get on the freeway with an overheating transmission and its going to crack, and O rings will burn. Looks like Im in the market for a new radiator, right? I recommend the 35.00 temperature gun at harbor freight as a first check. Forget codes until the temperature is tested. |
13th Apr 2014 6:21pm |
Actually no, I'd say the first place to start is the coolant lines. For them to be at 167 both going in and out may indicate a blockage. The myth behind doing a complete transmission flush and your transmission going to pieces isn't a myth. What happens is you brake down the sludge too quickly and the sludge blocks up the transmission and its lines. Since I had the wrong filter when I did the first flush I did it again once I got the correct filter. I doubt these radiators are prone to failure also but they could be. The place to really start though is to get the coolant lines blown out and make sure they aren't sludged up. For both to have the same temperature I am imagining a small amount of fluid slowly creeping through. To avoid sludge and blockage its best to regularly change your transmission fluid every 50,000 miles. |
13th Apr 2014 6:38pm |
