![]() | Home > General > 3.6 or 4.4TDV8? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
OK, I am SUPREMELY happy with the 3.6 TDV8 remapped by JE, it is simply amazing to drive, but if you have driven or owned both, when I look to change, is it actually worth paying the current £10K premium to have an 8 sp 4.4 over the 3.6?
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
4.2s/c Re map a good idea,
A remap on a 4.2? I think you need to change the pulley? Are you sure (sal) that you have a remap?
Just asking if you could re map a 4.2s/c ,
It didn't look like a question sal |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
RRUK, I have just got the 2010MY 3.6 Vogue se and i am really impressed, having had nothing but Range Rovers for years starting with a P38 4.0, then the 4.6 and then a TD6 i have to say that this one is quick, quiet and smooth and most of the time i really can not belive that i am driving a diesal engine. It standard, not remapped and to behonest i cant see any reason to touch it.
Thanks dmrr,
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
The 4.4TDV8 is a massive leap forward in terms of engine technology. I drove a 10MY 3.6TDV8 before the 4.4TDV8 was announced and was impressed with the engine. However, as soon as I drove the 4.4 I knew that it was a much better engine. The second difference in 0-60 (without chipping etc) is noticeable and its 50-75mph acceleration is pretty phenomenal. The 8 speed gearbox is exceptionally smooth for a single-clutch transmission and I think this alone makes a massive difference on fuel economy which, for a 4.4 litre engine, is excellent - it is actually possible to achieve Land Rover's quoted figures. The 4.4 also sounds very nice at higher revs... |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
Having had my 4.4 TDV8 for 9k miles I can confirm the thoughts of Johnson1. i regularly get 30-35 mpg showing on the dash. The auto box is really good and is always in the right gear even if it seems to by busy changing when pulling away from rest. The ride is significantly better and off road is a real revelation. The electronic stability programme seems to be more 'nannying' than before.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
yet again i have had green oval products all my life and only in the last couple of years swapped over to diesel from petrol.
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
My 3.6 was good once mapped but still not a patch on the 4.4 with 8 speed Far to many gone... |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
Certainly seems easier to get it flashing going around corners than previously. I think the ride is slightly firmer and busier on the new dampers. |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
I have put 22,ooo miles on the clock since I got the car last year having had a MY10 RRS 3.6 before that. I had the RRS chipped and it was great no doubt about it but hand on heart it was no match for the 4.4 this engine is even without re-mapping a complete beast and now that it is well and truly run in just gets better and better!!! However I don't think enough praise is made of the 8 speed gearbox which is sublime in it's operation and compliments the engine in every way and is probably the major factor in the improved mpg. For me it has to be the mighty 4.4 no question about it!!! |
22,000 in a year |
