Home > Maintenance & Mods (L322) > Viscous fan failure
Page 3 of 4 <1234>
Hoe much are the fan spanners and is there maybe someone near Doncaster/Warrington who could lend me them for a little bit to get the job done on mine?
I may be able to keep it after all but something else has really given Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #116238 3rd Apr 2012 5:54pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Can anyone confirm the size of the spanner needed? I am finding conflicting reports about 32mm or 36mm. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #116473 5th Apr 2012 10:11am
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Richcl wrote:
No viscous fan, 21c last week, and still half way up the temp gauge.
Would this still work if it actually got hot? Anyone from a warmer climate tried this? Should be ok now we are running up to Winter, but if I do this I'll have to keep an eye on it come Spring time...
Cheers - Gav
Post #116498 5th Apr 2012 12:40pm
@ flashman
You need 2 x 32mm spanners (for TD6) - one of them needs to be skinny - Halfords do them especially for vicious fans (intended mispelling!) and also a normal 32mm combination .
You might get away with one spanner, if you can use inertia to undo the nut, but it didn't work for me.
See my thermostat howto for photos
and note, the thread undoes the other way .
Post #116507 5th Apr 2012 1:27pm
Flashman
Thanks Joe, I will get a couple of the 32mm spanners and follow your pics. Tom
Current Drive
Previous Drives
Post #116537 5th Apr 2012 4:33pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Ref- "Brains Trust"
This is the UK, 21c is hot!! Laughing
Post #116566 5th Apr 2012 7:16pm
RRRob
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
Will I have had my viscous fan on and off numerous times , feel free to pop by and we could do what you have to do.
Post #116575 5th Apr 2012 8:02pm
Cheers Rob,
Drop me a PM if your about tomorrow as it fixed itself yesterday, then on the wya back from drayton it unfixed itself again! Censored
Mucho appreciated by the way Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #116600 5th Apr 2012 11:06pm
The Brains Trust
Brrr. Laughing Summer is over, but we are still heading for 30 today, but with a cool change this arvo - will be a bit chilly tomorrow - only 18...
But, on a serious note, I will try it without the viscous on and report back on if I have any overheating problems. I don't tow anything with it, so I doubt in the short term I will have any issues.
Cheers - Gav
Post #116614 6th Apr 2012 12:39am
Well time for an update Very Happy
Last Friday i popped by Robs and with his experience set about attacking the fan!!
Getting at the nuts was a burger to say the least as access is so restricted, even with the cowling moved a bit.
We finally got it loose and then spun it off Smile
Once off it still felt stiff and a quick look revealed the bearings had started to go on holiday, some completely and with them exposed and no grease in there they began to seize and thus the problem..
After removal the engine was super quiet Very Happy comparing to Robs TD6 i attribute the lower noise/clatter on mine to running on BioD for so long flushing and cleaning the fuel system out(she smokes sometimes when booted now I'm using normal petrol station rubbish!)
Also noticed on avg so far a 1mpg increase for me as well since its been fixed though i haven't been doing any fuelly updates lately Sad but am now just over 30mpg when cruising at 56-60 on the mway with AC on Smile
Its also so quiet now at any speed and doesn't have every tom d1ck and harry looking as i accelerate at any speed from anywhere thinking a harrier is coming after them!!
Rob, many thanks again for your help, the back passenger door may be next if your up for it Very Happy
And the temp has stayed firmly in the just a smidge to the left of the middle and not gone any higher even when sat for 5-10minutes crawling in traffic the other day when it was warm Very Happy
Though off to buy some new wheels this week to clean up and see if i like them or not Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #120417 5th May 2012 1:18pm
RRRob
Pleasure to help out Will . I may remove my viscous would just have to take in to account the trailer.
Yep up for rear door just gisa text when your wanting to do it.
When your wheel hinting would you look out for some 19 inch rims as we spoke about please .
Hope all is well in general .
Post #120423 5th May 2012 1:47pm
No worries rob Smile txt en route Wink
Gracious thanks again Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #120424 5th May 2012 2:13pm
ahebron
New Zealand
ahebron wrote:
Ah, it sounds like the TD6 is a lot like the 300TDi.
The 300TDi happily runs without its viscous fan.
These diesel Land Rovers are thermally efficient which I suppose is why LR fitted the FBH to all TD6.
RichL did yours sound like a Boeing 737 on take off, mine sounds like this at low speed till the engine passes approx. 2000rpm after that the noise disappears. Most noticeable from cold.
No sneaking away in my TD6.
Adrian
Sorry I haven't fololwed this up
Turned out it wasn't the fan, it was a burst intercooler Shocked
All fixed now.
Adrian VW Amarok 2014 Highline auto
Post #120478 5th May 2012 11:11pm
Wel time for an update.
Fan Removed i am seeing at least 1-2mpg improvement on the OBC (not doing fuelly yet sorry!) and this is mainly town driving as well...
The engine sat for 10minutes the other day in a very very long stream of traffic at 9am when it was at full temp and it was warm enough for all the windows down and a tshirt, the guage just stayed straight in the middle!
This is with the AC OFF as no point it being on unless windows are closed, and the engine seemed perfectly happy with it Smile
Over all unless you do tow a lot or are in a much hotter climate i don't think removing it is a big concern and if temps did start to claim whacking the AC on would quickly bring them back down for you or indicate your cooling system isnt up to par Smile
Again, Thank You kindly for your time Rob as it is greatly appreciated and when i get the chance i'll be bugging you for that rear door as the speaker rattles but im convinced its now dirt inside due to the way it rattle lol!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #123104 22nd May 2012 8:48pm
Don't forget the viscous fan will also help keep the gearbox cool Whistle
Post #123111 22nd May 2012 8:53pm
Page 3 of 4 <1234>
