Home > General > Car Park Access
Page 1 of 3 123>
Lapchien
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Car Park Access
Am a bit nervous about access height in car parts. I have a TDV8, on normal height would it get into a 2m car park restriction - including the roof fin?
Post #116835 8th Apr 2012 9:07pm
Yes, boarded a ferry twice last week on normal ride height with a 2m restriction and no problem...
Craig Thumbs Up
Post #116836 8th Apr 2012 9:11pm
When you enter a car park flip down your sun visor and all the information is there to calculate your air draft , good luck with the maths . 2008 MY Supercharged
Post #116837 8th Apr 2012 9:11pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Yes it will, but I do recommend lowering and locking to access height if you are worried Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #116838 8th Apr 2012 9:12pm
M44K TS
FFRR's fit no problem in most car parks I found.
The Prince Bishops car park in Durham is a bit tight in a FFRR though, even worse in my van, I had about 5cm of clearance between the roof of the works van and their PTZ/dome cctv cameras! 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #116839 8th Apr 2012 9:19pm
allycraven
managed a 1.88m limit locked in access height the other day, but it was a scary experience to say the least! Especially as there was a sloped roof and hanging pipes in the car park after squeezing through the height barrier at the entrance.
Won't be back there again any time soon, but the height restriction was only shown after entering a one way route and i had cars behind me, so I couldn't exactly reverse out again!
2m is easily achievable, but as the other guys already said, stick it in access mode first and you'll have less butt clenching moments!
Post #116840 8th Apr 2012 9:21pm
In normal mode the height is 1.93 metres. Thumbs Up
Post #116841 8th Apr 2012 9:27pm
ebajema
According to the visor, mine is 1.95 in off-road height with the roofbars on. Now who would go into a car park in off-road setting is beyond me ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #116843 8th Apr 2012 9:45pm
johnson1
Does anyone know if the height has changed over the years? Also why have the sun visor height stickers gone?
Post #116852 9th Apr 2012 2:36am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Not sure what's changed over the years but here's the extract from my manual (2007 TDV8):
A Overall width 2 216 mm 87.2 in
Overall width (mirrors folded) 2 034 mm 80.1 in
B Overall height
- Access height 1 820 mm 71.7 in
- Motorway height 1 840 mm 72.4 in
- Standard height 1 865 mm 73.4 in
- Off-road height 1 913 mm 75.3 in
The height is from the ground to the top of the aerial fin. Interesting that it shows 'standard' as 1.865 as opposed to the 1.93 mentioned above. A small but significant difference. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #116859 9th Apr 2012 7:57am
On the 2010 models the aerial fin on the roof is smaller Thumbs Up
Post #116872 9th Apr 2012 9:44am
paul r
What's motorway height? Is it if it goes over 100 and it lowers the suspension for stability?
Post #116888 9th Apr 2012 10:31am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
More or less. When the car is driven over a certain speed for a set time, the suspension drops. The speed and time vary with different models. On my car it's 50mph+ for about 20 seconds. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #116925 9th Apr 2012 12:42pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Is there a motorway height on the L322? The P38 had it specifically on the dash and you could see when it dropped but you can't on the L322??
The other solution for the car parks (I've done this!!) is to put the Venturecam on the roof and have a look how much clearance you've got!!
Post #116995 9th Apr 2012 8:52pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
There is a motorway height on the L322. on the height controls there are three on the right but one to the left of the control as well next to an image of a motorway.! It has a light to denote when you are in it, Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #116999 9th Apr 2012 9:14pm
Page 1 of 3 123>
