![]() | Home > Technical (L322) > Green Trailer light when towing |
Just hooked up the tintent (caravan) having had the 7 pin socket replaced with a 13 pin one for the new van and the green trailer light is on all the time. On my old D3 this used to flash with the indicators. Can anyone confirm if this is normal please?
This thing has a mind of its own. My trailer light never comes on, although all the lights work fine.... |
The answer is yes ,the green light should be permanently on to confirm you have trailer electrics connected |
Thank you Gentlemen, what a fine and helpful bunch you all are |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
I have been towing with mine for nearly five years and never knew there was a green light.
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
On my defender, it only came on when I indicated left or right. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Iknow this is old, but has anyone got any other points?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
Mine has trailer electrics and i tow often... My green light does not stay on on any of my past three FF's! Why/what did the indy do? Mine has always been plug & play...
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3940 ![]() ![]() ![]() |
Just to join the fun - mine stays on all the time when I have the light board of my bike rack connected.
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 745 ![]() ![]() |
Mine was a Westfalia 'plug n play' and does stay on. But I do use a converter, to convert from 13pin (I'm not sure if that makes ant difference)
trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141 ![]() ![]() ![]() |
Yes mine is on with electrics plugged in and off when not plugged in..... something works then!! 2006 MY Autobiography. With 'toys'
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
On my 2007MY S/C the green trailer light stayed on when towing. In my 2011MY no light at all when towing!? Current MY2020
Pretty sure handbook claims trailer light ON when hooked up. It's because you'd never notice otherwise |
As far as i know, and have been told by both the indy and the main agent, the land rocer kit is not plug and play, it will work but requires programming to activate the shut off for the parking sensors and ride height. Aparently.
