Home > Technical (L322) > Green Trailer light when towing
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Just to add to the confusion MY2012 flashes with indicators, my 2007 TDV8 stayed on permanently.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #116943 9th Apr 2012 2:59pm
Just arrived after my first long tow with a caravan on the back. All works fine. No flashing with indicators, fridge relay working, pdc cuts out and tows lile a dream.
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #116958 9th Apr 2012 4:58pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
My 2011my flashes with the indicators.
LR towbar fitted by LR.
Also comes up and asks what type of trailer is fitted and I had to put in various details about number of axles and distance from hitch to axle.
Ian
Post #117165 11th Apr 2012 11:04am
Ooo thats fancy.
Sounds like the latest models have a complicated tsp and anti snaking system. There is nothing that can't be fixed with a hammer😜😜
Post #117170 11th Apr 2012 12:17pm
Turbo Tony
The one I drove on the Land Rover Experience did that too. The Land Rover guy told me it was so it would draw the correct tramlines on the reversing camera - including both car and trailer... How the camera can see over a large trailer is beyond me, but with a smaller one, must be a really trick feature. Researching my first Range Rover purchase
Post #117190 11th Apr 2012 3:23pm
m90got
United Kingdom 2003 Range Rover HSE Td6 Alveston Red
Just to add to the fun i have just fitted the 7pin system and i dont get a green light at all,
but it has cut my sensors out and the ride hight doesnt change, of the joy,s of ownership Very Happy Current Stable:
Range Rover 2003 TD6 HSE Alveston Red, Sand Leather
Ford Focus C-Max silver 2003
V/W transporter Blue 1995
Yamaha XJR1300 Yellow 2002
Kawasaki ZX7R Green 1998
Honda CBR 600 Black 1998
Yamaha RD125LC Mk1 Red 1986
Yamaha RD125LC Mk1 Blue 1986
Post #117191 11th Apr 2012 3:34pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
I have a seven pin socket (westfalia?) and tow bar but have an adaptor lead to convert to the older 7 pin plugs on the van.
The suspension locks at standard height and the rear sensors turn off when all connected up but I dont have any green trailer light on the dash like I used to in my Disco 2 and Freelanders which used to flash with the indicators. I thought some sort of dash or audio indication was a requirement? I have not tried it connected to a van with a 13 pin plug if that makes any difference.
2005 td6 touch screen Mine was a blue one! Smile
Post #117310 12th Apr 2012 11:46am
IanV8
Andy
My 2002 did not have any warning light.
The requirement for a warning is to show that the flashers are not working so I assume that the bulb failure circuit will know that a trailer flasher has failed and give a warning.
I always meant to try mine but my van has double indicators on the rear so I would have to have taken 2 bulbs out.
Ian
Post #117421 13th Apr 2012 8:25am
Andy3681
Sounds reasonable Ian
might just pull a bulb out to see. What could possibly go wrong? Shocked Mine was a blue one! Smile
Post #117424 13th Apr 2012 8:40am
Right, have just hitched up the van electrics, we are away in it at the moment so nice and easy,
Removed the rear ns light cluster on the van and took off the indicator lead.
Trailer light on dash, no flashing with indicators.
Bulb removed, and i get a nice "check trailer lights" message.
All is good. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #117443 13th Apr 2012 10:51am
Andy3681
Must be bored this afternoon. hitched RR to caravan all as normal no warning lights of any kind. with indicator on took bulb out of caravan. warning bong and check trailer light message also car indicator speed up like there was a bulb gone onthe car. so all is well Thumbs Up Mine was a blue one! Smile
Post #118655 22nd Apr 2012 4:34pm
So they all seem to do something slightly different presumably depending on what type of install and the age of the ff. Rolling Eyes
But the bulb failure system should mean that come mot time anyone with a 13 pin electric system will pass as they are now testing these. Not 12n and 12s sockets though. There is nothing that can't be fixed with a hammer😜😜
Post #118694 22nd Apr 2012 9:07pm
