Home > Technical (L322) > Wheely rubbish wheel weights
Bit of a problem with wheel balance,
I was seeming to get a bit of a shimmy at about 70 (ahem 80) mph, when I got home I had a look at the front wheels and the outside wheel weight had fallen off the passenger side wheel.
Took it into quack fit and had them re balance the wheel. Great
On the way home the inside weight fell off Big Cry The same wheel.
Again off to middling tyre centre, they rebalanced it again. 500 yds down the road the inside weight fell off again. Different company balanced it. Different make of weights.
I have the standard 19" vogue alloys so they are designed for rim weights but what are they doing wrong. The weights look fine and seem well attached when I leave the garages.
Anyone had this very strange problem. There is nothing that can't be fixed with a hammer😜😜
Post #116821 8th Apr 2012 5:05pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I thought the weights on alloys wheels always went inside the wheel so as not to be visible when fitted.
Post #116825 8th Apr 2012 6:12pm
Alloys usually dont have a lip. These do.
Its how it came with fresh tyres from the lr main dealer. There is nothing that can't be fixed with a hammer😜😜
Post #116827 8th Apr 2012 6:50pm
daveo
are we talking stick on or clip on... V8 facelift Range Rover Autobiography 22" wheels.
Post #116829 8th Apr 2012 7:11pm
Clip on weights. There is nothing that can't be fixed with a hammer😜😜
Post #116830 8th Apr 2012 7:22pm
I think stick on is the answer then Thumbs Up
Post #116856 9th Apr 2012 8:13am
enumbers
Ireland 2004 Range Rover HSE Td6 Adriatic Blue
We fit a lot of tyres in our garage and never have any trouble with proper clip on weights for alloys but the stick on one s work fine aswell once you clean the rim properly.
Regards
Post #117256 11th Apr 2012 9:55pm
there are indeed quite a few different clip on weights, if you dont use the correct type then they will fall off.. ... - .- -.
Post #117298 12th Apr 2012 8:58am
Post #117299 12th Apr 2012 8:59am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
You can say that again Very Happy No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #117386 12th Apr 2012 10:12pm
thats not like me to double post....... Shocked ... - .- -.
Post #117429 13th Apr 2012 9:18am
Mr. Green ... - .- -.
Post #117430 13th Apr 2012 9:18am
