Home > General > how to change the date of my brake fluid service indicator
Robhibbert
2012 Range Rover Vogue TDV8 Santorini Black
My dealer forgot to change the date so does anybody know how i can do it myself without having to go back?
It is a td6 2002 if that helps
cheers
Post #11688 26th Jan 2010 2:27pm
dan_uk_1984
Where is the brake fluid change indicator kept!?
Post #11702 26th Jan 2010 3:25pm
Robhibbert
The date is shown when you first put the key in. Where the mileage for service is shown if you press the odometer button the date for fluid change is shown
Post #11703 26th Jan 2010 3:32pm
dan_uk_1984
That's not for the brake fluid though.... That is the Oil Change and Inspection.
This is for the petrol, not sure if it works on the TD6:
Resetting the Oil Service or Service Interval Message.
Ignition key must be “off”.
• Press and hold the trip odometer button in the instrument cluster (left button), and turn the ignition key to the first position (KLR).
• Keep the button pressed for approximately 5 seconds until one of the following words appear in the display: “OIL SERVICE, or “INSPECTION”, with “reset”.
• Release the reset button and press and hold it again until “reset” begins to flash.
• While the display is flashing, press the left button briefly to reset the service interval.
After the display has shown the new interval, the following will appear: “END SIA”.
Post #11708 26th Jan 2010 3:47pm
Robhibbert
Why is the date changed every two years then?
Because its the interval for changing brake fluid! As its a BMW range rover it is exactly the same as my previous bmw and my wife's mini
I dont ever recall getting a date for service on there just the mileage to service
Post #11709 26th Jan 2010 3:50pm
dan_uk_1984
Read the manual that came with your car before you start second guessing the info that I give. If you cant even be bothered to do that then don't ask the question in the first place if you already know it all!
Post #11712 26th Jan 2010 4:00pm
Robhibbert
I dont know it all hence why i asked the question but i think you'll find it was you who started the patronisation with the exclamation on your first reply.
I have read the manual but it says nothing about it which is why i came here for support
Go and check what date it says on your vehicle and see if it is the same as when your oil change/service is due, i'll guess it prob isnt correct
Post #11714 26th Jan 2010 4:07pm
dan_uk_1984
The RR has two or three levels of service:
Oil Service and Inspection 1 (possibly also inspection 2 although unsure if this is flagged on the dash) I have atatched the service sheets for you.
Post #11716 26th Jan 2010 4:31pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
as dan said oil service , insp 1 and pos insp 2 brake fluid is every 3 years or at insp 2 which is same difference
also being as yours is a 2002 yours should have had the brakefluid changed in 2008 or its due in 2011 whats the service history say Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #11748 26th Jan 2010 7:01pm
