Home > In Car Electronics (L322) > Bi-Xenon upgrade
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Bi-Xenon upgrade
Can I upgrade my normal Halogen lights to Bi-Xenon without emptying my bank account? Do I need to activate it, and do I need any other kit Rolling Eyes Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #117825 16th Apr 2012 9:29pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
A lot of the time you find the headlight units are completely different although they appear similar. There is a ballast / igniter pack for each bulb and also a linkage that attaches to the rear suspension as Xenon lights must have an automatic levelling system (to comply fully with the law). The headlight switch is sometimes different too as Halogen headlights sometimes have an adjuster incorporated into the switch to lower the beams as you increase the load in the vehicle.
Another 'legal' requirement is a headlamp Wash/Wipe. I'd imagine to retrofit OEM units would need some changes to the wiing loom. The loom may already be in place for the components needed, a lot of marques install the looms to cater for all options and just omit the components if there not required for that trim level.
If its the later 'active' style Xenon lights there would also be an input from a Steering angle sensor and likely an additional control module.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #117828 16th Apr 2012 9:44pm
DMRR
Cheers, there's no height adjusters ... guessing it is because the vehicle is on air, and therefore will level itself. It has washers. I wasn't aware that they came with non-xenons tbh, but miss my adaptive lights from the 2010. This one doesn't even do the Clarence the cross eyed Lion on startup Sad Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #117830 16th Apr 2012 9:46pm
dave699
You could try one of the 'Canbus error free' type aftermarket kits from a popular auction site.
There are two types of bulb the one designed for a reflector Halogen enclosure usually has an 'R' after the bulb designation e.g. H7R, H4R.
Do you know if your headlights are Reflector or Projector?
Projectors usually have a round domed lens over the bulb.
Had it, loved it!
2007 Vogue SE TDV8
Post #117831 16th Apr 2012 10:04pm
DMRR
They are projector, don't think any L322's have any other type. I find it odd that I've owned 4 of the things, and 3 had Xenon's .... and this one doesn't. Guessing they were an option on the pre-2006 I had, but ..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #117836 16th Apr 2012 10:25pm
DMRR
...are H7's Xenon? Am I confusing myself now Sad Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #117837 16th Apr 2012 10:31pm
DMRR
Chatting to myself ... it seems it's D2S for Xenon...so I'll just get some ice 6500k lights for the dipped..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #117839 16th Apr 2012 10:42pm
dave699
H7 is a Halogen bulb, if that's what fits in your headlamp try an auction site search for H7 HID kit or similar, be sure to check the reviews etc as some of the kits available claim to be error free and as soon as they're fitted you get a bulb out warning on your dash.
Had it, loved it!
2007 Vogue SE TDV8
Post #117849 17th Apr 2012 7:35am
You might also want to have a look at prices, I've just been trolling through Famous Four's site:
Halogen headlamp unit : @ £194
Bi-Xenon headlamp unit: @ £594 Big Cry
Though you can get replacement lenses and seals for @ £50. (up to 5A999999 )
Off to buy some light guards Wink .
Post #118037 17th Apr 2012 11:02pm
DMRR
Bought the new H7's ... open up the dim/dip to find it's Xenon. Question why is there :
1. No flash when they start up like all my others....
2. No adjustment check like all my others.... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #118566 21st Apr 2012 10:17am
fisha
Depends on the ballast driving it ... its the ballast that ignites the arc at a much higher voltage than the general running value, and then drops it down to normal. Maybe your ballast doesnt do that as much as others.
On normal cars, they dont have air suspension, so to counter any suspension differences ( such as weight in the back ) the levelling adjustment is done by the shutter inside the light unit. Cause the RR runs on air, that levelling adjustment is done by the cars suspension, so as long as the headlamp is set correctly for a level car, then it wouldn't need to have an adjustment check.
I've never seen my bi-xenons do a level adjustment either. I know that the shutter works, as you can see if flip up when it goes full beam, but I've not seen it do the down and up thing that my mini cooper does. V8 or else ...
Post #118572 21st Apr 2012 10:47am
