![]() | Home > Technical (L322) > clonk from suspension |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35740 ![]() ![]() |
....it could be a 'clunk'..
Stan the search system is very difficult to use mate, I guess sometimes questions have to be asked |
I wonder if Stan just has this awesome memory, instead of using the search function. Who knows, Stan may be the real secret of Googles success but wants to remain anonymous |
the search function [with instructions how to use] is there in addition to the OP being able to scroll down and flip a few pages to find threads with the same subject.
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
where one find the compliance bush on the range rover and any idea how to set/replace it - apparently it contributes to the clunking noise [/u] |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Are you sure its not the drop links. Cheap and easy to change, don't even need to jack the car up to change them? Reformed |
Front suspension consists of bottom balljoints, drop links, anti-roll bar 'D' bushes, compression links and transverse links
thanks for the reply. thus far we've replaced drop links, lower arm bushes, tie rod ends, etc. the only things on front suspension that has not been replaced are the struts and shocks[/url] |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I'll try my dead cat in the engine undertray again |
stevenA Member Since: 23 Jan 2011 Location: Paris, France Posts: 34 ![]() ![]() |
The bush that connects the tie rod to the subframe is a compliance bush (see microcat) and is located just below the height sensor -it is a round bush with an asymetric core. If it is not aligned correctly, movement of the lower arm, instead of being absorbed by the bush, cause the inner and outer parts to touch hence the clunk.
hi steven
Perhaps this is not the problem!
eventually the clunk has disappeared. solution to the irritation, loosening and tightening the subframe as well as all joints and bushes with the car on all 4 wheels on the ground and, voila clunking gone.
