Home > Technical (L322) > RSE Buzz
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
RSE Buzz
Hi
My dealer can't find an issue with an RSE screen that I think is an issue. Every time the display on one screen dims (which I am assuming when main lights are on?) there is a constant 'buzz' from the screen. If it goes bright again, no problems - buzz goes. They can't replicate the problem and therefore are assuming it's normal. Anybody else have an idea/the same problem?
Thank you.
Post #118242 19th Apr 2012 9:37am
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
Not had that on mine. I don't think my screens change brightness with lights on ?? They only go dim in between a screen change or swap from dvd to tv to radio etc,
Have you tried various DVD's to see if it's the actual disc causing it ?
Post #118254 19th Apr 2012 10:59am
i would check the connections on power and video feed ...these wires can get 'chaffed' under the seat... ... - .- -.
Post #118256 19th Apr 2012 11:09am
Rolo
"chaffed" Is that when a chav breaks in and tries to steal the dvd player ? Laughing
Post #118321 19th Apr 2012 6:01pm
