Home > Technical (L322) > L322 air con drain plug?
WAZZY786
United Kingdom 2006 Range Rover Vogue TDV8 Stornoway Grey
Anyone got any pics or illustrations as to where the a/c drain plugs ("rubber nipples" are? I can't see them when I was under the car :/ or is there another way to check the a/c drains are clear?
Post #119552 29th Apr 2012 1:38pm
fisha
turn the aircon onto max. look underneath, should see 2 drip puddles appearing ... happens quite quickly. V8 or else ...
Post #119564 29th Apr 2012 3:43pm
WAZZY786
Ah so is there no rubber nipples as such?will give it a go next time it's dry up here Smile
Post #119565 29th Apr 2012 3:50pm
fisha
There will be pipes ... I just cant really remember where they actually come from. One each side of the gearbox directly below where the heater is. V8 or else ...
Post #119744 1st May 2012 8:04am
