Home > Technical (L322) > *HDC inactive* & *Air Susp Inactive*
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Hi guys i pulled into my drive last night with the rover on full lock to the right and the dreaded BONG sounded with *HDC inactive* & *Air Susp Inactive* displayed on the dash and dropped to access mode i left the car for a few mins then took it out for a run again, no errors displayed and the ride height was normal again until I put the car on full lock to the right again same thing happened the BONG and the message *HDC inactive* & *Air Susp Inactive* and lowered to access mode the car still drives etc and when you stop switch the ignition off then start up a few seconds later everything is clear and works normally could it be just a sensor as the suspension pump only runs for a couple of seconds on start up so I can't see it being the air pump or a leak? Anybody got any ideas?
Cheers stu
Post #119765 1st May 2012 10:25am
CBH25
Australia 2003 Range Rover Vogue 4.4 V8 Santorini Black
This is exactly the set of errors I got last week when I was going around a wet round about and lost traction (turning hard right).
When you were turning right did you lose traction on any wheels? L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
L322 4.4 Vogue MY05 - Sold to my brother
P38 4.6 HSE MY97 - Regretfully sold
Post #119918 2nd May 2012 10:55am
stuboy00
Hi there no loss of traction and no other issues apart from the suspension dropping to access mode but it is now happening every time the car is put into full right lock? Someone must have some ideas on this as I really don't want to visit my local stealer Big Cry
Cheers stu
Post #119925 2nd May 2012 12:00pm
CBH25
The loss of traction I was asking about was not after the error message, but during your full right lock manouver?
Are you turning a steep uphill or downhill corner which lead a wheel to scrabble for traction?
I'm wondering whether theres a link between the Stability control activation in your problem..... L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
Post #119926 2nd May 2012 12:02pm
Cheers stu
search "hdc inactive" with quote marks stu, loads on this.... ... - .- -.
Post #119929 2nd May 2012 12:07pm
stuboy00
Hi Stan I did a bit of research before i posted and I'm going to check the speed sensor behind the wheel but apart from that there isnt really anything that is the same as what is happening with my rover ? It's gota new batteryby the way so it's not that either
Cheers stu
Post #119933 2nd May 2012 12:33pm
from what you have said in your first post it does sound like the speed sensor... ... - .- -.
Post #119937 2nd May 2012 1:02pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Just a random thought I have been looking at my front height sensors as they are playing up and I cant bottom it yet but the height sensor is directly above the steering rack. The cable or plug are not getting caught or damaged on full lock? Mine was a blue one! Smile
Post #119939 2nd May 2012 1:06pm
stuboy00
Hi Stan no I didn't do anything after replacing the battery but this problem has only just occurred the new battery was installed in February? Wink
Cheers stu
Post #119944 2nd May 2012 1:25pm
stuboy00
Hi Andy how do I get to the cable is it easily accessible (under or through the engine bay) do you have any pics for reference
Cheers stu
Post #119949 2nd May 2012 2:26pm
Andy3681
Hi Stu
Not in the car at the min so cant sort photos but if you turn the wheels on full lock and look from the front the height sensor's are directly above the track rod. The cable comes out the bottom Via a waterproof plug ( I think they vary from year to year) the cable then goes behind the wing liner and up the side of the plastic box that has the connectors for the brake wear and abs sensors then off to the ecu. Mine has an intermittent earth fault according to the code reader even when unplugged but I cant find anything obvious and have replaced sensor, Plug and the first 9" of cable ( it comes as a repair kit).
So I need to start at the ecu end next. Mine was a blue one! Smile
Post #119950 2nd May 2012 2:39pm
Andy3681
PS been reading previous threads because of my own fault but I think you need a fault reader to pinpoint the fault. The battery seems a fav talking point. good luck Mine was a blue one! Smile
Post #119991 2nd May 2012 7:22pm
stuboy00
hi guys ive had a look behind the passanger side wheel and found this now im pretty sure its not right as i would think that the bottom wire (white) should be covered somehow to protect it? can anybody tell me what it is? is this the speed sensor?
cheers stu
Post #120000 2nd May 2012 9:00pm
Brake pad sensor wire
Post #120004 2nd May 2012 9:45pm
CBH25
Guys for future reference knowledge, I had a faulty Brake Master Cylinder which completely fixed this error when replaced. L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not Smile
Post #124807 3rd Jun 2012 8:25am
