Home > In Car Electronics (L322) > Digital TV tuner.
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Digital TV tuner.
Sorry for all of these new owner questions (I haven't picked my car up yet and I've got too much time on my hands, clearly) but on a 2007MY car will the TV be digital?
Was it standard on the 07 S/C Vogue SE? If not, what are my upgrade options?
TIA. Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #119935 2nd May 2012 12:42pm
stu
yes it should be, my 07 TDV8 has a digital tuner, but i have upgraded it to the newer one that displays the electronic program info.
boys and their toys.. Laughing
if you want one of these give Wiggs(Adrian) a shout, i am sure he will sort you out.. Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #119983 2nd May 2012 6:31pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I looked at a 56 plate (Dec 06) 07MY (Terrain response etc ...) SC 4 weeks ago and it had an analogue tuner and old style key.
IIRC there is a thread somewhere that tells you what VIN they changed to hybrid but definitely not all 07MY's had it.
Post #119993 2nd May 2012 7:28pm
I think all TV's are analogue upto 09my... Please correct me if anyone knows differently?
Craig Thumbs Up
Post #120024 3rd May 2012 12:06am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
My 07 Supercharged has digital TV, although I couldn't say if it was factory fit. Also it's a bit stuttery too so I never use it.
Post #120032 3rd May 2012 6:58am
simon1233
Craig - 57plate (MY08) TDV8 has hybrid tuner as standard Whistle Thumbs Up
Post #120033 3rd May 2012 7:19am
jfb1977
I haven't picked my car up yet, but when I do - what's the easiest way to tell if it's digital or analogue? Embarassed Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #120066 3rd May 2012 10:48am
Bow down thank you sir Bow down
Craig Whistle
Post #120069 3rd May 2012 10:54am
Have a search in the wiki for its location, the hybrid is half the thickness of the analogue... If you need/want a hybrid one, send me a PM...
Craig Thumbs Up
Post #120070 3rd May 2012 10:57am
jfb1977
I did have a rummage Craig, but I must be being thick / blind as I can't find anything.
I'm guessing the tuner box is somewhere in the back with the nav drives etc?
I'm also assuming that if my TV doesn't work at all then it's probably analogue given that the digital switchover has just happened...? Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #120077 3rd May 2012 11:13am
stu
if you look in the cubby hole that houses the nav drive, look down into the hole and you will see a silver box with a couple of fakir type arial connectors a most conector and a power connector, obviosly a silver box. that is the TV Tuner. you should be able to read the label on it to and it will say hybrid tuner if it's digital.
Wiggs (Adrian) sells the newer hybrid boxes with the electronic menu display and they are plug and play.. Thumbs Up
i bought mine for my TD6 and swapped it into my TDV8. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #120084 3rd May 2012 11:23am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
My 56 plate has hybrid Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #120085 3rd May 2012 11:25am
jfb1977
Thanks guys. Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #120090 3rd May 2012 11:35am
Does yours have RSE?
Craig Thumbs Up
Post #120092 3rd May 2012 11:37am
jfb1977
Yes. It does. Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #120093 3rd May 2012 11:42am
