![]() | Home > Technical (L322) > Is there a wire that signals a connected trailer? |
The trailer electrics work on the brake lights, when you plug in the electrics it senses a greater load through the brake light circuit and then it does its stuff (through the various ecu's). If you were to cut the wire to the break lights in the trailer plug then the car would not know there was a trailer on the car...
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
Outrageous idea - but how about controlling your relay from the reversing light (on the trailer) ? |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
Thank you for the ideas. I will test them out. I don't want the relay on the trailer, but if no current is sent to the reverse lamp on the trailer unless there is extra load on the brake light curcuit, then I can tap into this wire between the trailer ecu and the socket. ----------
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3985 ![]() ![]() ![]() |
When you select reverse +12V goes onto the trailer reverse light connection in the 12S socket whether you have a trailer connected or not.
Thanks Nicedayforit. Then I'm back to where I was. |
There is one possibility concerning the rear parking sensors.
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
Reverse lights are probably the best bet; just don't use a relay, at least not directly.
Thanks again for your ideas. From Rave it seems like PDC is controlled by canbus and with my knowledge I don't think I should fiddle with that.
There is of course the simplest way of all, guaranteed to work, the manual on/off switch. |
