Home > In Car Electronics (L322) > Newbie to do list
Scrappy
Newbie to do list
Hello al
I have recently bought a FFRR MY04 it came from an auction so just working through the inevitable to do list, however this seems mainly limited to the ICE system/s.
The TV tuner is missing, but as this would need upgrading to digital not hugely fussed but anyone suggest a good replacement.
The only sat nav discs with it are two 2004 ones for France so not much use as I live in Leicestershire Smile again anyone know a good source for updates at a reasonable price.
Finally I can not get the CD cartridge to come out the player, the display states no CDs in the machine and when I push the button it tries to eject the cartridge. but it looks as though one of the individual CD holders(number 3 I think) is in the play position so effectively stopping the cartridge ejecting anyone have any suggestions on next moves.
Regards
Gary
Post #120645 7th May 2012 9:05am
stu
firstly hi and welcome Gary!!
if you want a TV tuner you need to get in touch with forum member "Wiggs" (Adrian) he will sort you out i think.
this link will sort your sat nav issues i think..
http://www.satnavi.com/landrover----range-rover.php
in my eperience unless you can gently with something thin slide everything back in to place it is a changer out and top casing off to rectify that one.
enjoy your new car hop all above helps.. Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #120661 7th May 2012 10:05am
Scrappy
Thanks Stu, that reply is really helpful, much appreciated.
Gary
Post #120679 7th May 2012 11:41am
stu
sent you a PM too!! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #120680 7th May 2012 11:46am
A small long screwdriver normally allows you to slide the CD's back into the cartridge from the front if done carefully...
Craig Thumbs Up
Post #120806 8th May 2012 8:41am
Scrappy
Thanks Craig
Tried screwdiver can't get it to slide back.
Followed the guidance to remove glove box last night, but can't get glovebox to drop.
The part of the dash that contains the passenger cup holder is stopping the glove box from dropping.
The guidance clearly shows it remains in situation but the glove box has a lip that sits behind it - so at a bit of a loss really.
Wil have to have another try at the weekend
Post #120997 9th May 2012 1:25pm
