Home > Maintenance & Mods (L322) > Inspection
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Inspection
Hi All,
So I am now getting the message "Inspection 05/12" when I turn on the car - thing is the garage that I bought it from carried out a full service (or so they said) when I bought the car at the end of February and this has been stamped into the service book.
Presumably they didn't reset the service light.
Found this on the search - Will it work for a TD6 Facelift with touchscreen?
Quote:
Service Interval Indicator Reset Procedure
The service interval can be reset with the following procedure using the instrument pack buttons. TestBook/T4 can also be used to reset the service interval indicator by connecting to the diagnostic socket and following the reset procedure.
NOTE: The distances and dates shown are examples only and not necessarily representative of actual messages displayed.
Check and Reset Procedure
1 Ensure that the ignition is switched off.
2 Press and hold the LH instrument pack button.
3 With the button held, switch the ignition on to position I (AUX).
4 Continue to hold the LH instrument pack button for a further 5 seconds, until the “SIA RESET” appears.
5 The message centre will display the distance to service status as “RESET SIA: 3600km/mls” and the type of
service (OIL SERVICE or INSPECTION).
6 Check that the reset distance limit has been reached.
a If yes, proceed to step 9.
b If no, proceed to step 7.
7 Press the LH button once. The message centre will display the date to service status as “RESET SIA: 03.12”.
8 Check that the reset date limit has been reached.
a If yes, proceed to step 11.
b If no, proceed to step 10.
9 When the distance reset limit has been reached or exceeded, press and hold the LH button for 5 seconds.
“RESET” flashes in the message centre five times.
a If the LH button is not pressed again before the fifth flash of “RESET”, the reset will not be performed. The
message centre will display “END SIA: 3600 km/miles” for 5 seconds and the display will change to the
service date “RESET SIA: 12.03”.
b If the LH button is pressed before the fifth flash of “RESET”, the service distance will be reset. The message
centre will display the new service distance “END SIA: 25000 km/miles” for 5 seconds. The service date will
then be displayed.
10 Press the LH button once. The message centre will display “END SIA” for 2 seconds. This ends the service
interval check and reset.
11 When the date reset limit has been reached or exceeded, press and hold the LH button for 5 seconds. “RESET” flashes in the message centre five times.
message centre will display “END SIA: 03.12” for 5 seconds. “END SIA” will be displayed for a further 2
seconds and the service interval and check will be ended.
b If the LH button is pressed before the fifth flash of “RESET”, the service date will be reset. The message
centre will display the new service date “END SIA: 04.12” for 5 seconds. “END SIA” will be displayed for a
further 2 seconds and the service interval and check will be ended.
The service interval indicator system can only be reset again after 2 1 / 2 gallons (10 litres) of fuel has been recorded as used by the instrument pack.
 African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #120974 9th May 2012 11:04am
Johnte
I think that only applies to Pre 'Touchscreen'. It wouldn't work with mine, I actually bought a Hawkeye, to do the job, I figured this would be a good investment anyway Wink
Post #120976 9th May 2012 11:14am
DeRanged Rover
So I guess that means re-opening the Hawkeye v IID Diagnostics debate again ...
Ho hum ... Whistle African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #120979 9th May 2012 11:27am
Johnte
Just sent you PM (unrelated to topic) Thumbs Up
Post #120982 9th May 2012 11:52am
DeRanged Rover
Hi guys, having now got the iid tool, i can't figure out which menu option I need to click into to reset the service/inspection indicator.
Any topis from the fellow iid users/testers out there?
Thanks!
C African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #127507 25th Jun 2012 10:14am
