Home > Technical (L322) > Hot battery cable
Andy
Hot battery cable
THis morning, whilst checking the oil, I noticed the point where jump leads are attached was all melted around the terminal, to such an extent, that the post had retracted inside the plastic cowling and towards the battery.
Is this a common thing, or anyone else had this happen? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #121021 9th May 2012 4:30pm
There is a lot of heat generated when jumping a vehicle and if the clamps are not connected properly it will cause the symptoms you have
Post #121034 9th May 2012 6:22pm
Especially when I connected up the cables the wrong way round. Melted cable covers though, not the connection point plastic Big Cry .
Post #121040 9th May 2012 6:53pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
A bad connection will generate heat make sure its all cleaned to ensure good contact and all terminals are tight. Shorting them out or connecting wrong like Joe will cause a large current that will melt the insulation off the cables and could set you Range on fire! Mine was a blue one! Smile
Post #121041 9th May 2012 6:58pm
If the plastic cowling is seriously distorted due to heat I would be inclined to suggest you consider replacing it.
The cowling effectively acts as insulation keeping the 12V starter cable bolt from the earthed body panel the cable bolt passes through. Any deterioration in the cowling risks the starter cable bolt shorting onto the body panel.
It's always possible that the bolt is already shorting intermitently causing heat that has affected the cowl.
Post #121047 9th May 2012 7:44pm
