Home > Technical (L322) > Suspension fault - again
Andy
It's happened again. However, this time, the indicator lights are on. I've got the message "AIRSUSP.INACTIVE" as before, but last time it happened, there were no lights on the control knob. This time, it is illuminated as though its in lock mode.
Strange thing is, it still self levels at traffic lights, inclines etc. I can hear it running in the boot on start up as well.
Any fixes? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #118739 23rd Apr 2012 10:59am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Had that once (may have been related to low battery voltage after an externed interior session though).
Stopped the car; checked the boot for water below the spare wheel (none); started again and everything back to normal - hasn't reappeared again ...
Post #118752 23rd Apr 2012 2:23pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
Is it possible you may have a leak? Mine showed inactive a few weeks before both front struts gave up.
Maybe try setting it in offroad mode and seeing if stays like it, give it time and check all the bags are inflated. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #118767 23rd Apr 2012 4:17pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
on the touchscreen version if you look at the off road screen you can see the feedback from the suspension height sensors thats how i found out 1 of mine was faulty. dont know about the earlier screen though sorry Mine was a blue one! Smile
Post #118819 23rd Apr 2012 10:43pm
Andy
Daz
I can't select offroad height as its locked. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #121325 11th May 2012 4:42pm
daz62
Sorry I realised you might have that problem after I replied. I presume you have tried the lock to lock steering fix to clear air susp inactive, it didn't work for me but worth a try.
I am not sure if disconnecting the battery may clear it, alternatively appeal for anyone with the allcomms thingy near you to reset it then try setting to offroad.
Good luck 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #121337 11th May 2012 6:45pm
This does sound like what happened to me. Small leak in Drivers Side Front Suspension Air Bag.
The RAC AllComms cleared the fault, raised to off road, big hiss !!!
You'll need diagnostics to clear the fault, then the problem should become evident .
Post #121340 11th May 2012 6:54pm
daz62
It did exactly that on mine Joe, the leak is most prominent at offroad height. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #121342 11th May 2012 7:04pm
