Home > Technical (L322) > Indicators come on as brake lights
Hoveronly
United Kingdom 2006 Range Rover Vogue SE 4.4 V8 Zambezi Silver
L322...Problem somewhere. When braking, the rear indicators light up and brake lights dont. Indicators act normally otherwise. A quick fix anyone? Tried to find a 322 electrics diagram but no joy.
Post #121327 11th May 2012 4:49pm
could be a short but for both to do that its very weird..
downdload rave , there's a wiring diagram there.....link in the wiki. ... - .- -.
Post #121329 11th May 2012 5:00pm
Obvious question sorry, but you have not changed a bulb or touched any connector have you? Previously..
Post #121330 11th May 2012 5:37pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
earth fault? Mine was a blue one! Smile
Post #121336 11th May 2012 6:43pm
just a thought, what happens if you have the hazards on and then brake? ... - .- -.
Post #121347 11th May 2012 8:03pm
Another for an earth fault Thumbs Up
Post #121356 11th May 2012 8:11pm
ahebron
New Zealand
3rd for an earth fault.
Adrian VW Amarok 2014 Highline auto
Post #121424 12th May 2012 7:51am
Reformed
4th for earth fault! When I was chasing a slightly different issue with my indicators I checked, cleaned and checked again all the earth points I could find. Turned out that one of my number plate bulb holders was slightly touching the chassis hence my weird light glitches. Bent it back and been fine since? Reformed
Post #121435 12th May 2012 9:07am
Hoveronly
Thanks for the input guys, does seem like an earth issue. Checked all connections, fuses, had a wiggle at all and sundry and its working normally again. Could have been the damp I guess as it has poured non stop here for days. Thumbs Up
Post #121483 12th May 2012 2:56pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
I had the sme problem a couple of years ago with a Honda civic. Same fault, especially when the weather was damp. Thhe indicators came on under braking. Had it, in an out of the garage numerout times. To cut a long story short, the mechanic spliced a new earth wire into each of the light clusters at the back and ran them to a suitable earth point (possibly chassis, but cannot rrcall) and this solved the intermittent problem. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #121664 14th May 2012 6:59am
