Home > Maintenance & Mods (L322) > Drivers heated seat not working
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
So I discovered today that the heated seat function no longer works, the light just goes off after a few seconds. I have searched the forum for info. The test mode doesn't work. I have checked for lose connections.
it's probably the seat element, and my warranty won't cover it.
There are seat heat elements on the bay but they say they are from 07 on? What is the difference?
Are the heat elements for 06 built into the leather seat covers?
I have had suspension errors I have put down to the battery, could this also be the case here?
Thanks
Post #121231 10th May 2012 9:43pm
Lolo
Bump... Bow down
Post #121470 12th May 2012 12:51pm
I think that the seat element was integral with the leather upto 6a9999999 and separate from 7a000001 acording to what i can deduce from microcat. There is nothing that can't be fixed with a hammer😜😜
Post #121471 12th May 2012 1:03pm
Lolo
Thanks, what I thought.. Thumbs Up
Post #121472 12th May 2012 1:12pm
Big Jim
Scotland 2006 Range Rover Vogue SE Supercharged Zermatt Silver
Sounds exactly what happened to my 2006 SC
Passenger heated seat worked fine but driver's seat light went off after 1 or 2 seconds and never even warmed up !
Before you make the same mistake I did, and order from LR then throw the old covers away, check out the advice given to me by others on the forum.
http://www.fullfatrr.com/forum/topic8761.html 2006 Supercharged
Post #121540 12th May 2012 10:18pm
it may be worth testing which one back or squab is broken. if its like any other element it will have electrical continuity if good and show none if bust. easily testable with a multi meter.
Just a thought, but if you have java black leather and the back is gone......
http://www.ebay.co.uk/itm/GENUINE-RANGE-RO...821wt_1037
check it is the right partnumber/what parts you need here:
http://lrparts.ru/engl/
russian web page but works fine for reference. There is nothing that can't be fixed with a hammer😜😜
Post #121544 12th May 2012 10:34pm
Lolo
Thanks, so I'll just wait to see if I can get a bargain on the bay for sand leather covers
Don't fancy shelling out much for new covers, BUT it will play on my mind, and the seat could do with nice new cover..
We shall see how it goes, preferably before winter..
Thumbs Up Thumbs Up
Post #121550 12th May 2012 10:53pm
Googsy
Is replacing the cover a DIY job or more specialised ? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #121716 14th May 2012 12:11pm
