Home > Maintenance & Mods (L322) > Pre 2010 headlight upgrade?
Hill Billy
2007 Range Rover Vogue TDV8 Java Black
Just seen these on ebay item eBay Item No. 150813925593
What's your thoughts? TDV8 3.6 OVERFINCH 57
Post #121610 13th May 2012 4:45pm
daveo
just in the middle of doing my ones, i will be keeping inside of the light standard and using covered smd rings, dont like the fact that you can see the smd bulbs on his ones, i fill 8000k is way to blue, factory bulbs are 4300k and not 6300k as stated V8 facelift Range Rover Autobiography 22" wheels.
Post #121614 13th May 2012 5:13pm
Hill Billy
Interesting, look forward to seeing yours! Do you heat them in the oven to split them?
I have seen some others on Pimp My Range but look nothing like 2010 ones. I'd be keen to have a go at the mod if a similar angel eye look could be achieved. TDV8 3.6 OVERFINCH 57
Post #121620 13th May 2012 6:07pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
i would love to see these angel eyes with the standard back colour, and the standard bulbs in day light and at night as well, dipped beam and just side light would be great
Matt
Post #121644 13th May 2012 10:19pm
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Good work Hill Billy! I saw this item months ago, forgot to add it to my watch list and couldn't find it again - I've been looking for it ever since!
I'm not interested in the light upgrade, but I do want to colour code / modify my orange reflectors in the headlight and these guys should be able to help me do that. Thanks! Thumbs Up Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #121652 13th May 2012 11:29pm
daveo
i am using the 120 smd rings but they have the plastic diffuser over them like the 2012so you wont see the yellow smd through the clear plastic, it looks ugly when you can see them.the rings i have ordered are 6000k and will be visible in bright daylight, i think i will wire them to my side lights so i can have them on when i want..
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #121653 13th May 2012 11:35pm
daveo
hold on before you going spending big bucks, splitting the lights is not that hard, i dont use an oven just a heat gun, i have done a step by step guide on how to get them apart, it will go on to show how to fit the halos V8 facelift Range Rover Autobiography 22" wheels.
Post #121654 13th May 2012 11:39pm
mattstevenson2005
where did u get the rings from dave, and how much?
Matt
Post #121668 14th May 2012 8:18am
Hill Billy
Could you post a link to the headlight splitting procedure.
Do you think it would be possible to add a triple row of LED's to mimic the 2010 indicator? TDV8 3.6 OVERFINCH 57
Post #121669 14th May 2012 8:23am
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
looks good Dave
i will speak to you about mine as this is what i want done as well
Post #121674 14th May 2012 9:57am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Hi Dave
Where did you get the halo's from? I want to do my fogs as DRL's like a few others have but the normal halo rings I have found on the bay aren't bright enough as they dont have the lens to magnify the light.
Ta
Andy Mine was a blue one! Smile
Post #121693 14th May 2012 10:37am
daveo
ok, i have done a deal with the suppliers to get this set at half price, they run at around £70 for the full kit including loom and relay. now as i have not tried these so i dont know if they are any good, but i will let you know, they are meant to be around 6000k i dont want to go any higher then that as they look to blue, yes they do rings small enough for the fogs, you can if you want put yellow led's behind the reflector as craig has done,
i will post the how to when i get a min.. V8 facelift Range Rover Autobiography 22" wheels.
Post #121766 14th May 2012 4:52pm
