Home > Maintenance & Mods (L322) > TD6 Gearboxes - how robust is yours?
I8A Jeep
South Africa 2003 Range Rover HSE Td6 Buckingham Blue
OK, i'm reading with more and more concern about the failing gearboxes on our TD6's as my car seems to be right in the 'fail' range, with 150k km on the clock. What i'd like to know is... am i sitting on a time bomb here, with an inevitable failure just around the corner, or are there many vehicles out there that are still going strong at high mileage. Any experiences you have - with tips for your long-lived boxes would be very interesting.
Post #121699 14th May 2012 10:57am
5IMON
Mine failed at 70 k but was replaced under warranty. Tip- Get a warranty (warranty direct) Thumbs Up
Post #121710 14th May 2012 11:24am
piecost76
Mine went at 112k miles. PO had it refurbed at a cost of £2k! Big Cry
2 schools of thought here - either change your gearbox oil & that may postpone any failure or by changing the oil, you may dislodge something that could accelerate its demise.
If you have no symptoms yet (slow to take up drive or jerky changes or won't lock up) then an oil change could be the way ahead?
Personally, I would keep on driving & be prepared for a kick in the nuts when the inevitable comes! Whistle Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #121713 14th May 2012 11:35am
Mine has just turned 60k and from reading on this forum I have decided, if it ain't broke don't fix it.. Too many stories of faults after oil and filter changes to the gearbox. Previously..
Post #121719 14th May 2012 12:17pm
I8A Jeep
Thanks guys. I'm also in two minds whether to do the oil change or not. at the moment it feels to run fine, certainly no jerking or failure to take up drive. perhaps the 'if it aint broke....' approach is best option.
Post #121735 14th May 2012 1:10pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Took ownership of mine with 126k on the clock so dropped oil and filter and replaced with genuine filter and fluid. After a further 3 months dropped and changed the fluid again, now got 142k on the clock and shes sweet as a nut Wink Fingers crossed ! I wonder how many miles the Police got out of their TD6 boxes ? Rolling Eyes
Post #121829 14th May 2012 11:29pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
See my previous post about faulty filters But if its good I would just check the oil level if its wear in the valve block changing the oils will not help.
Now a question had a conversation with an ex police mechanic about the gearbox he seems to think that using it in sport a lot can have an affect on its life, I can see where he is coming from as if you are using sport you will presumably be driving harder and it will use different valves in the transmission ( I think) So those with failed boxes grandma or boy racer? Mine was a blue one! Smile
Post #121854 15th May 2012 9:21am
Reformed
Let's hope so, as I drive mine like an old fart! And I'm young! Thumbs Up Reformed
Post #121857 15th May 2012 9:45am
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
I went through 5 td6 gearboxes in 120,000 miles.
2 did not last 5000 miles and were faulty!
Post #121869 15th May 2012 11:17am
Vogue
were these 5 recon or new boxes? there must have been a fault, or they were not installed and filled with oil correctly, for two gearbox's to last 5k miles there is obviously an issue somewhere and I don't think that can be put down to LR. Yes failures at around 100 to 120k miles is well documented, but 5 boxes in the same period is just wrong.
Post #121913 15th May 2012 4:38pm
I slot mine into S but use it more like a manual to force 5th and lock up when pootling at about 30-35 where it wouldnt normally allow lockup Sad once you get past 36 in D it locks up nicely but as soon as you drop below it changes down again Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #121945 15th May 2012 7:31pm
mercs600
Never driven with the S function - I have tried it and it does work though and the vehicles never towed - so that could be the reason why its standing up to the 140k+ mileage Wink
Post #122011 16th May 2012 2:23am
I suspect that a few of the TD6 gearbox issues relate to a driving style that simply cannot be matched by a TD6 gearbox due to the demands put on it by a heavy Range Rover that it was not 100% designed for.
TD6 that have been driven sedately seem to go on and on....
Post #122021 16th May 2012 7:34am
Same here, just why i fitted paddleshift to my SC... Makes it much better to drive and i must be saving at least 30% of gear changes...
Craig Thumbs Up
Post #122024 16th May 2012 7:55am
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Mine has now done 64K, I bought it 18 months ago with 43K on the clock. So far so good. I drive it very steady and I have never towerd and was told the car was never used to tow by previous owner. Taking these factors into account I am hoping my gearbox goes on and on. That said I am thinking of doing a geabox oil change in the next few months. Still undecided. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #122179 16th May 2012 6:42pm
