![]() | Home > Technical (L322) > TDV8 Gearbox Fluid |
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 ![]() ![]() ![]() |
Hi,
Olders, I recommend you call Gordon at 4-Tech. He's Cambridge based so not too far from you. This is a subject which has a different answer depending on who you talk to. What I will say however is that these gearboxes are not sealed for life. If the fluid is not changed you end up with transmission shunt and clonky changes.
RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48 ![]() ![]() ![]() |
Land Rover have a service schedule for the TDV8 stating milage/age.
stolen from RRPHil for the benefit of others
Land Rover sell it as Land Rover M1375.4 about £20 for a litre. |
£22.00 a litre |
That is all fantastic info chaps. Many thanks indeed |
£250 is about right, certainly by what I paid last time. If you can find anyone who'll do it for £150 then post up please |
Many thanks. |
Pants , I should have read the OP properly . |
Preventative. Not worth not doing to my mind. -----------------------------------------------
If you wait until the box is showing fault symptoms then it's too late... |
What I was going to say before I realised it has been said at the beginning is that Land Rover only recommend changing the transmission oil on petrol engined FullFats with a 6 speed ZF transmit ion 2008 MY Supercharged
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3951 ![]() ![]() ![]() |
Stan,
