Home > Maintenance & Mods (L322) > Tdv8 gearbox again
supershuttle
Tdv8 gearbox again
So it's doing it more often now, going into neutral before picking up again after a quick slowdown particularly with some lock on - roundabouts! The IIDTool actually says up down switching fault whatever that is. It does seem to clear and drive normally although interestingly Sport mode can't be selected - you can move the stick across but the car stays in drive. This actually fixes itself after a restart - needless to say dealer can't replicate - anyone had similar or got any ideas Geoff
Post #122118 16th May 2012 12:58pm
there's another member who found his gearbox pump had gone, could this be your problem geoff... ... - .- -.
Post #122120 16th May 2012 1:15pm
supershuttle
Stan,
The post you put on the wiki about gear linkage mechanisms looks like I should do that first as it describes a lot of my symptoms, particular number1.
http://www.fullfatrr.com/wiki/TDV8_Gearbox...s_of_drive
Now I assume the gearbox is somewhere under the car and I can easily find it / lol Geoff
Post #122192 16th May 2012 6:24pm
Oy that's my post not Stans on the Wiki Laughing
Post #122194 16th May 2012 6:25pm
supershuttle
And again Embarassed Geoff
Post #122221 16th May 2012 7:59pm
appropriate credit put on wiki post.... Thumbs Up ... - .- -.
Post #122292 17th May 2012 7:38am
sleepezy
Also having similar issues (no prizes for guessing the mileage...)
Out of interest, when I lose drive there is no gear indicated on the dash. It goes completely blank, not even showing D, S etc. does anyone else have the same symptom or am I looking at a different problem?
Cheers
Post #122299 17th May 2012 7:47am
supershuttle
Well I found the gearbox and after at first trying this fix with my long arms and a mirror - couldn't fit my fat frame under the car- I nipped round to a mates house who has trolley jack and axle stands and got going with the WD40 followed by Lithium grease. He knows stuff and says not to use copper grease on linkages, I don't know stuff so slapped on the general purpose Lithium based grease I took round.
Drive home - try as I may I couldn't get the car to misbehave so maybe job done Thumbs Up
It is intermittent so I'll give it a week and report back. Very Happy Geoff
Post #122664 19th May 2012 3:45pm
jinkytoby
nice to know it aint just the td6 box thats made of cheese ( just a joke) bit like all the range rover gearboxes Rolling with laughter Rolling with laughter
Post #122759 20th May 2012 12:51pm
supershuttle
Jury is of course still out on this fix but as it costs virtually nothing and takes 10 minutes it falls into the category of preventative maintenance.
As soon as I mentioned "gearbox issues" on this forum lots of panic buttons pressed and many suggestions made as to how I might spend money and how I was ultimately doomed and would certainly have to buy a new gearbox - all, I think, based on problems with the 5 speed.
Interestingly the D3 forum has a lot more on this subject as the 6 speed is in the TDV6 et al and this is where this fix originated.
As I say it's early days but promising so far - fingers crossed Very Happy Geoff
Post #122760 20th May 2012 1:24pm
supershuttle
It would seem that the problem I had with the car dropping into neutral for a second when slowing, turning and accelerating I.e. roundabouts where you don't stop or bends on winding roads is fixed thanks to this site and the wiki that suggests lubricating and greasing the linkage on the side of the auto box.
Thanks to all who offered advice but I'm pleased to report that none of the more expensive (in some cases much more expensive ) remedies were required. Greasing this linkage should be part of any service - so if you've got a TDV8 and the gearbox is playing up as described above (or similar) this is the first thing you should try its free takes 10 minutes some WD40 and some grease and it worked for me Thumbs Up Geoff
Post #123578 25th May 2012 8:27am
rory
Just had the same issue on my SC fixed by my indy. Thumbs Up
Needed new linkage and bush but still a nice cheap fix.
Cheers
Rory
Post #128227 28th Jun 2012 6:44pm
Might be worth asking garages to lube it up as a matter of course during any service. ShOuld be cheap... There is nothing that can't be fixed with a hammer😜😜
Post #128271 28th Jun 2012 8:35pm
sleepezy
Just picked my car up from the garage having had this issue fixed.
They stripped down the linkage and found the pivot bush to be shot per Stan's Wink link. Common on Disco's but relatively rare on FF's...
Done under warranty for me but they showed me the invoice which was only for £50 odd.
Post #128296 29th Jun 2012 7:26am
All good Thumbs Up
Post #128307 29th Jun 2012 8:17am
