![]() | Home > Technical (L322) > ZF 5HP24 valve block available for substitution test |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
If anyone’s having problems with their ZF 5HP24 transmission (’02–‘05MY 4.4 V8 models) which they believe may be valve block related then I have a spare valve block that I’ve just rebuilt and checked which you’d be welcome to try to see if it fixes the problem. If you’re a regular contributor to the forum then no deposit is required, if you’d just pick up the bill for the postage costs (approx. £20 each way).
Very generous offer Phil |
as above kudos for being so generous Phil |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Kudos to you Phill. You really are a true gent and gearbox guru! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
That's an awful nice lookin |
*looking MY2010 TDV8 Vogue Ipanema Sand
