![]() | Home > Technical (L322) > flat battery |
Your jump lead connections are different from mine, |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
You noticed?
Exactly .... |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 ![]() ![]() ![]() |
unsure if the newer years has however it is as far as i know the final stage relay for the heating and air con it controls when the blowers are powered up and when they switch off, the school of thought is that they sometimes fail to give the correct switching and the heater blowers dont switch off or continue to switch on and off at regular intervals. the result of this is the battery taking a hamering and eventualy giving up and failing when you need it most. a newer model of the relay was brought out and instead of being plastic it is now with metal conducting plates in an odd shaped triangle. it is very easy to change, but is easily as awkward to change you will find it in the drivers footwell after the the centre trim has been removed and the trim around the pedals has been taken off (star drive needed) it is right in the corner almost were the center console equipment reaches the front bulkhead. it will clip out and takes about 20 min to locate change and put back together hope this helps ![]() i can get the part number if you require, my stealer told me that they never change these and the parts guy mentioned that they get through verry little of these items however they had 4 on the shelf????? i was not sure that it was the fault and i changed the bty as it was absolutly well and truly used to it life end, however i did have a run of intermitant flat battery before i changed them both and none since so i cant say it was it for defo but for a cost 100 quid or so for the battery and around 50 for the relay i have had (touch wood) no starting problems ever since 02 Range Rover HSE Zambezie silver 4.4 Last edited by andyw on 2nd Feb 2010 9:58pm. Edited 1 time in total |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
TDV8 battery sizes.................. amp hours ........................cost ...............supplied from......................
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
Well i forgot to nip to LR yesterday and was greeted to a flat battery this morning!
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
they quoted me £150 for a Bosch last week!
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2071 ![]() ![]() ![]() |
Go to GTR Trafiic in Bamber Bridge, |
Just bought mine at LR this morning for £110.
that was a good deal, they quoted me £99, but this was ex VAT and they wanted £25 ex VAT to fit |
wardpg Member Since: 27 Jul 2008 Location: Preston Posts: 76 ![]() ![]() ![]() |
My original flat battery saga continues-flat again this morning would not even turn engine over, found out later that radio had lost all its stored stations so must have been really down. Called LRA and AA man arrived in 20 mins-good service. He tried a booster start but nothing, then jumped started which eventually worked after leaving cables on for about 10 mins. Tested battery and charging said all ok. then when shut engine down and locked up car it was still drawing 7 amps after 15 mins.
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 280 ![]() ![]() |
A combination of using the pre-heater with only short journeys in between, has led to a couple of occasions where the car would not start due to a drained battery. The manual states that the heater should shut down if the battery charge drops too low, but it seems this did not happen until it was too late to conserve enough juice to start the engine.
Paul
WARDPG.
