![]() | Home > Technical (L322) > Drivers memory seat fault |
| Neil E Member Since: 05 Jan 2010 Location: North West Posts: 60
Hi All,
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
Can you explain in a little more detail for us exactly what is working and how and what is not working and how? It may help us diagnose you see. Discovery 4 HSE
It`s working today??
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
Mine does it now and again. Doesn't really bother us now (I drive it most of the time anyway!) 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883
is the process not in the owners manual steve? ... - .- -.
| 6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101
Mine is in German (!!) and the one in the WIKI does not explain how to use them but does show you the components.... |
ah, ok ....you can look online on 'topix' but the site is down at the moment...have a try tomorrow.
Thanks Stan. I did a quick search for electric seats but it only came up with fitting a Britax Childs seat. I then tried gaining access to the owners handbook but it came back with an unexpected error message, so perhaps the site is still down. I will have another look later or perhaps I need to register first. |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
Put the key in the ignition then set the seat, steering wheel and mirrors to where you want them. Press the M button on the seat, then press the desired number lets say 1. That stores those settings in memory 1.
And if you set the seat, mirrors and wheel to another position for the Lady friend with the other key and set it at memory 2, the next time she gets in the car using that key, it should remember her settings when the car unlocks (Unless you have used the 2nd key and moved the seats)
Thanks, that's great. The test will have to wait until late July as it is currently aboard a container ship in the Atlantic Ocean on its way to Cameroon! |
| All times are GMT |
