Home > Technical (L322) > Blocking protection problem - front wipers
RRPhil
I’ve been having a problem with my front windscreen wipers just stopping for no apparent reason while they’re switched on (I don’t mean the ‘intermittent’ function – this is in both normal and fast ‘continuous’ modes).
Having read the workshop manual I know that the wiper mechanism has a ‘blocking protection’ function which cuts the power to the wipers if they’re switched on and there’s no wiper park signal received by the Body Control Unit for a period of 16 seconds (e.g. if the wipers are frozen to the windscreen or something physically obstructs them from moving). The BCU then only turns the power back on again after waiting 3 minutes or if the ignition is turned off & on again – and sure enough that’s exactly what mine do, although neither waiting for 3 minutes or keying off the ignition is much of an option at 70mph on the third lane of a motorway while passing a truck that’s throwing up huge quantities of spray.
Although I always believe that an ECU is the very last thing that should be blamed for a fault I thought I’d better first check that it wasn’t sat in a puddle of water or something due to a leak. I removed the passenger seat to inspect the BCU and its connections and everything looked absolutely fine.
Body control unit lives under passenger seat
BCU
I used my Faultmate to check for DTCs for the Body Control Unit and sure enough it had stored “Wiper motor blocked, park switch or wiper relay defective”. The wiper relay only costs £5 so I thought I’d try that first
Wiper relay is mounted next to transfer box ECU behind the battery
but when I phoned to order one I was told by the Land Rover dealer that they’d never sold one before – the clear implication being that it was unlikely to be the relay at fault. I therefore decided to buy a new wiper motor/linkage assembly instead.
I’ve now fitted it and - guess what - the problem is still there Crying or Very sad . I took the old motor apart to examine the park switch and there’s nothing obviously wrong with it
Cam on motor drive gear which activates park switch
Wiper park switch
I’ve therefore now ordered a wiper relay and am waiting for it to arrive. In the meantime I’ll have to keep my fingers crossed that this is going to fix the problem.
I just wondered if anyone else had had a similar experience with their front wipers?
Phil
Post #122708 19th May 2012 11:44pm
Just because LR have never sole one before doesn't mean they can be faultless.
Post #122729 20th May 2012 8:42am
Hope you get it fixed... But, what a great, detailed write up. Well done.. Thumbs Up Previously..
Post #122738 20th May 2012 9:40am
Ive seen two with similar complaints... Both needed replacement BCU's...
Craig Whistle
Post #122742 20th May 2012 10:28am
RRPhil
Okay, thanks. In that case I’ll try the new relay first, now it’s on order, but it sounds like I’m going to end up needing a new BCU. My BCU has been superseded twice by Land Rover since 2003 (from YWC000921 to YWC000922 and now to YWC000923) so I’m trying to find out from Blackbox Solutions if my Faultmate MSV-2 will allow me to get the new hardware & software versions to work on my vehicle.
Phil
Post #122879 21st May 2012 2:00pm
JonP
2003 Range Rover Vogue 4.4 V8 Epsom Green
Hi Phil
I had a similar problem with mine about 5 months ago same fault wipers would just stop
I replaced the wiper relay and to date not had a repeat failure hopefully yours will be the same
I did open the relay and found a small of loose metal floating about inside the case
Regards Jon
Post #122885 21st May 2012 2:40pm
RRPhil
Thanks Jon - that sounds encouraging!
The new relay should arrive tomorrow, though unusually it's not looking like I'll get chance to test the wipers this week Smile
Phil
Post #122952 21st May 2012 7:26pm
RRPhil
Just a quick (& hopefully final) update. I’ve used my wipers for several hours now since fitting the new relay and not had any issues at all so I’m confident that, like JonP, this £6 part was the problem
Just a shame that I’d spent £127, unnecessarily, on a new wiper assembly before getting to this point! – ho hum.
Phil
Post #125483 9th Jun 2012 5:27pm
Not like you Phil (says the man who bought a new transfer box motor that only proved he didn't need one!!) .
Post #125511 9th Jun 2012 7:42pm
thatgirl101
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
I've just come back from a trip to France in our L322 and experienced a similar problem - the wipers just stopped randomly and only turned back on when we restarted the ignition.
Do you happen to know the part number for the wiper relay?
Post #272076 21st Jul 2014 5:03pm
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
ywb000060 ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #272113 21st Jul 2014 7:43pm
thatgirl101
Hi,
Does anyone have any tips on accessing the wiper relay? Can the battery just be moved forward (whilst still connected), or does it need to be removed completely?
Thanks
Post #278198 30th Aug 2014 4:25pm
It has got to come out! .
Post #278203 30th Aug 2014 5:30pm
thatgirl101
Thanks - all done. And like the poster above, the relay that I took out quite obviously had some loose parts in it. Hopefully that will fix the problem - I need a nice long rainy drive to test them out!
Post #291862 9th Nov 2014 7:27pm
mzplcg
^ Careful what you ask for unless you fancy gathering 2 of every animal on the planet. Thumbs Up
Post #291886 9th Nov 2014 9:13pm
