![]() | Home > General > Need information. |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
the wear issues with tyres that you refer to is specific to the Touareg. i would still suggest that you change tyres in axle sets on the FFRR as good practise, it just lets them wear evenly, but there is no need to change all four at the same time unless they all need to be changed. Current: TDV8 (3.6) RRS HSE
Ludo Member Since: 02 Dec 2011 Location: Montignac Posts: 27 ![]() ![]() |
Thank you STU for this. That's good to know, it was an issue on the Touareg! Do you know something about the 2005 facelift? Ludo |
Turbo Tony Member Since: 06 Apr 2010 Location: London Posts: 243 ![]() ![]() |
Hi Ludo,
the early models have headlight wipers and the facelift just has washer jets!! don't forget the touch screen on the facelift too!! Current: TDV8 (3.6) RRS HSE
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8483 ![]() ![]() ![]() |
The picture below is a pre-facelift 2002-2005ish model
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34972 ![]() ![]() |
a facelift can have the pre-facelift gear stick layout.. ... - .- -.
and a pre facelift can have the touch screen nav, just to make it more confusing. |
Hello,
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
Ludo - the "facelift" interior pictured is from 2006 onwards (2007MY). The most obvious way to tell is that the car will have an electronic handbrake, not a normal handle and also the new Terrain Response off road system. You'll also notice that the ignition key is now on the dash.
Rykard Member Since: 16 Apr 2012 Location: Leicester Posts: 74 ![]() ![]() |
I presume there will be a big jump in prices for the facelift models? cheers
When I was looking I didn't notice a big jump in price. At least not for cars on the 'cusp' between non-facelifted and facelifted.
