![]() | Home > Technical (L322) > Squeaky Rear Suspension ?? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801
re posting pics,
| Luckyluciano Member Since: 29 Oct 2011 Location: Wiltshire Posts: 121
I don't think it likes me. All I get is this message;
give martin a pm, he'll sort it.. ... - .- -.
Right I've now done 300 miles since doing this "fix" and it appears to have worked |
| DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379
Lucky, which fix did you do - the syringe into the Bushes or just the WD 40 Spray?
| daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201
Update.
Hi, I used 3 in One oil spray. It comes with a small red tube like WD40. Firstly I jacked the car up and removed the wheel. Then with some needle nose pliers I managed to pull the protective rubber cover back (upper and lower hub bushes) and spray onto the bush.
Thanks - I'll try that this weekend and let you know how I get on. African Bush Junkie ... in London!
| tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283
I have a horrendous squeak/creak from both sides of mine I think coinciding with weather warming up. It squeaks terribly if you bounce on the rear door sill at rest and also when driving, mostly from the rear but also on parking up when the suspension settles there is the most awful creak. I have sprayed all with copper grease then with silicon grease a week later and also filled the ball joint covers with WD40 til is squirted back out at high pressure (used a 20ml syringe and 20G 1" needle if anyone is interested!) all to no avail, the question is does anyone know a good way to identify which bushes or ball joints are to blame as will replace them myself but dont want the car out of action for too long so want to order the bits first. Unless someone can tell me if any of the rear bushes never need replaced and that to do all possible suspects is economic???
Hi Tom,
OK good call, I will see if I can give them a waggle when its stopped raining, maybe bu next march or so.
Got a bit of an update on this.
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Handbrake cable is around £30 per side, not too difficult to do
Cheers I'll have a look now |
