![]() | Home > Maintenance & Mods (L322) > Damn puddle lamps! |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
So I p*ssed about with my mirrors and my puddle lamps today for about 20 minutes, but couldn't for the life of me work out how the hell to get the bulbs out.
Shove a screwdriver in - on the INSIDE (i.e. nearest car), push it in a bit, then pry. Out they pop (you are inserting the screwdriver to push a tab) Land Rover Addict
Cheers DMRR. That's where I was inserting the screwdriver, but nothing was happening apart from a few cracking noises. I really felt like I was just going to break something.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
What model year we talking? I'm sure (I could be wrong as I did the job a while ago) that you prise the covers from the front of the mirrors, and access the lamps that way. |
My car is a 2007.
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
Just use an old credit card and go round the edges of the cover first, the light holder just twist then pull. Bulbs just push in. Range Rover 4.4 V8 Vogue |
Sorry Glideman - can you explain a bit more - what do you mean the edges of the cover?
Where the cover joins the main body of the mirror. Gently push the card into the gap until you free all the clips, then pull the cover forward. Range Rover 4.4 V8 Vogue |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
This is what the approach light on my 2005 looks like.
HTH David |
Sorry thought you meant the mirror covers |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
FYI if it helps, I posted this a while back. 2006 vogue
Lolo,
Ooops well too late now but good to know. Thanks
Awesome! Thanks all for helping...am off out to play! |
