![]() | Home > Maintenance & Mods (L322) > Headlight LED update. |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
In case anyone is interested, I've finally found a combination of dipped beam, main beam, sidelight, cornering and foglight bulbs that I think work really nicely together and give the look I was after.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Good work and well documented.
So..firstly an apology for the quality of these pictures. I'm not exactly a dab hand with a camera. I'm sure there's a setting on it that would work better (camera is an Olympus PEN EPL1) so if any of you are photography gurus, just let me know what settings I should be using and I'll try again!
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
Excellent write up |
Your OSRAM sidelights are *not* road legal. Just thought I'd better this point this out if this becomes a wiki.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8055 ![]() ![]() ![]() |
I think they look fantastic - matching lights has been one of my issues over the years, but never bothered with fogs - that's attention to detail |
Guessing so - it's like fitting 100w lights over 55w, or as it seems not E-Marked.
Be careful with the H7's too - the ebay site isn't very clear on whether those are 55w or 100w - but there is a tiny warning near the bottom of the page!
Thanks for the heads up!
It's a doddle Robert, but you just need to ensure you follow the instructions in your owners manual properly. There's a whole section on replacing bulbs. You need to remove the grille first (3 screws), then there are 3 screws holding in each headlight unit. Once you've undone them the lights just slide out and then you'll be able to remove the various bulbs very easily. It's 20 minutes tops to do both sides. ![]() 2007 Porsche 997 C2S Coupe 2007 FFRR 4.2 S/C 2012 Jag XKR 5.0 S/C 2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP) 2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion 2012 Porsche Cayenne Turbo 2018 AMG C63S Estate 2015 Mercedes GLE63S 2017 Maserati Levante Diesel 2017 Audi A6 Avant 3.0 Black Edition |
Guys - I just did a bit of work on my headlights (colour coding the orange reflector) and noticed that the 100W H8 bulb in the cornering light is actually beginning to melt the headlight housing and mark the actual lens of the headlight. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
i think that's been well documented that 100 watt bulbs are hotter than 55 watt and they are totally illegal in the uk unless used in spots... ... - .- -.
Well, clearly I'd missed those documents!
Rykard Member Since: 16 Apr 2012 Location: Leicester Posts: 74 ![]() ![]() |
it was easier back in the day when headlamps were made of glass and not plastic. I had 90/130 in my Jetta as well as a few spots on the front - it was great lol cheers
