Home > Technical (L322) > Car refused to move
rjp996
United Kingdom 2003 Range Rover Vogue Td6 Buckingham Blue
Car refused to move
Odd one this, wondered if anyone else had had it. Started up the RR coming home tonight, put it foot on break (felt a bit solid, but did not thing to much about it). Put it into drive, foot off break and the car would not move. Put it in and our of drive and at that point thought the break peddle felt rick solid with no movent. Then noticed both the battery and oil light were on !!!!
Turned off car, turned back on - break peddle went it normal , a bit soft to the foot and car drive normally (no error lights). Does the RR have some system that disengages drive and licks the breaks when it has some trouble ????
Post #123312 23rd May 2012 8:56pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Sounds like the engine hadn't actually started!
The reason the brake (not break!) pedal was solid was because there was no vacuum assistance as the engine wasn't running!
Post #123314 23rd May 2012 9:00pm
These old TD6 engines are whisper quiet Thumbs Up
Post #123322 23rd May 2012 9:18pm
Simes
Heh, perhaps he had a loud CD of tractor engines through the ages playing?
Post #123323 23rd May 2012 9:19pm
rjp996
You may well be on to something (extreme embarrassment....) sure I had it running, but.... Well it was the end of a very long day ;-)
Post #123345 23rd May 2012 10:21pm
Simes
Heh
I've done the same once. Admittedly mine is the much quieter petrol!
Post #123346 23rd May 2012 10:25pm
mjdronfield
My "Someone is being cheeky about the Td6 noise" alarm has just gone off !! Laughing
Hopefully, you had just not started the engine.
Not as easy to tell as a petrol, as the fuel gauge tends to stay in one place whilst you are putting your seat belt on.
(It's started........)
Seriously, the Td6 is a bit pants from outside noise wise, but having had a remap, mine is much better, and inside, unless you are giving it a bit of welly, you don't hear it as much.
Mark
. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #123367 24th May 2012 8:31am
Simes
Paging Mr Dronfield...
The Doctor can see you now ...
I SAY, THE DOCTOR (YES DEAR, THE DOCTOR) CAN SEE YOU NOW... YES NOW... ITS THE ROOM AT THE END MARKED DEAFNESS CLINIC.
Post #123373 24th May 2012 9:02am
mjdronfield
Rolling with laughter
WHAT ???
It's hotter in the sea where ?
........half past two..........
i must admit, the V8 suits the RR better. My 3.9 Classic was quite nice, but not 11mpg.........
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #123395 24th May 2012 10:32am
Off Topic ... - .- -.
Post #123400 24th May 2012 10:42am
Simes
Pssst...
Mark - you're in trouble...
Post #123408 24th May 2012 10:49am
mjdronfield
Good point.
Apologies. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #123412 24th May 2012 10:58am
